Just installed sprint booster and 997 shifter - Review
#32
There are two camps, people who have used Sprint Booster and love it, and those who attempt armchair engineer the product from a far and feel they know everything about the product. What we always like to see is people who can put their personal bias's aside and try it. Its at that point when people tend to realize the true benefit of our product. Our product is tested everyday by every day people, and when they do they are besides themselves on how well the product works.
So again, we ask, have you tried our product. We have no problem with your opinion, but before you dismiss our product out right, we rather you try it and speak from personal experience. We have won awards on our product. And generally Porsche owners overwhelmingly enjoy the benefits.
Even when our Sprint Booster was being reviewed for the SEMA award. If you read closely it happens that the review was conducted on a Porsche.
Again, we invite you and everyone else to try our product. And then report back what you like, or what you didnt like. We listen to our customer's feedback so we can always improve our product and the technology that we have brought to the market.
#33
Don't let the Sprint Booster advertiser confuse you. I'd like to dispell the myth:
It does NOT and NEVER will decrease DBW lag. Motronic is still going to do what it does with the throttle valve. The SprintBooster products do NOT intercept or circumvent the signal between the ECU and the throttle body. All it does is amplify the DC Voltage between the pedal and the ECU. There is NO lag there.. NONE. (well aside from the lag of the speed of electricity, which is not accelerated by SprintBooster. )
Claiming that SprintBooster decreases DBW lag is completely and blatantly false advertising. It does no such thing.
The Pedal returns a signal to the ECU, 0-5v DC. What Sprint Booster does is simply amplify the signal, so if you depress your pedal 30%, it might send a signal to the ECU indicating that you pressed it 50%, or 60% or whatever the gain is set to. YOU CAN DO THE SAME THING by simply pressing the gas pedal 50%, or 60% instead of 30%.
So effectively, Sprint Booster reduces the accuracy of your throttle pedal by shortening functional travel of the gas pedal. (Since if pressing the pedal 80% tell the ECU you pressed it 100%, you lost the last 20% of pedal travel doing anything)
It's really quite simple, but Sprint Booster sales and marketing people will tell you it's complicated, or it does this or that... but at the end of the day it's a dc voltage amplifier with selectable gain with a 5v max output.
See through the smoke and mirrors folks!
It does NOT make your car any faster (unless you're phycisally unable to push your pedal 100% by yourself ), it does NOT DBW reduce lag (physically impossible due to it's location and complete separation from motronic).
As I stated before if you already have an engine that is rev happy at the blip of a throttle, will this even make a difference?
#36
That settles it. 997SSK it is. Thanks for all the input guys. I new this mod bug was going to kill me
#39
I'd go to the dealership and try shifting a regular 997 first in the showroom before u make your decision. I'm sure the 997 short shifter is really good, but give the regular one a try first. I had a short shift when I got the car and hated it- so it's not for everyone.
#40
Meh, it's a dc volt amplifier, with selectable gain now. You can get the same effect by simply pushing your gas pedal more. People feel the same change as if they had simply driven with more gas pedal in the first place. If they want to drop a bunch of money on a voltage amplifier instead of just pressing the gas pedal more.. then great! Those people are keeping Sprint Booster in business!
I agree it WOULD be truly amazing to drive a modern car with zero throttle. How's the air going to get into the motor?
#41
We are simply asking if you have tried the product and are speaking from personal experience or if you are speculating. We have explained at length already to you and everyone observing this thread what our product does, And what sets it apart from everything else.
#42
Here's the part from Suncoast Porsche in Flordia:
http://www.suncoastparts.com/product...de=performance
Pretty good price--its worth every penny!
went to porsche and spoke with the techs, $50 bucks cash out the door, dont buy new, so many p car guys have them replaced with SSK's and leave the stock unit there.
#43
As I understand it, with the sprintbooster, when you are at 80% of pedal travel, you are in fact at 100% open throttle. Why did you design this amplifier to essentially cut out the last 20% of the throttle movement? Why not design in in a nonlinear fashion? What I liked on the M3 was that the Sport button made the throttle more sensitive in roughly the first 50% of travel and then tapered it off in the last 50% of travel. Even with the Sport mode on, 100% open throttle was reached at 100% pedal deflection. The throttle was nonlinear on the M3 with the Sport mode on. It did not however make the last 20% of pedal travel nonfuctional. This makes sense to me. What doesn't make sense is why your product cuts out the last 20% of padal travel. Is it because the amplifier is just simply boosting the pedal signal in a linear way? I would really like to know as I was considering buying you product but do not like the idea described above. Thanks......
#44
This was posted on AZ in a thread about Sprint Booster: http://www.peony888.com/VS/SprintBooster.pdf
This was an analysis conducted in 2007.
#45
https://www.6speedonline.com/forums/...ml#post2832536
https://www.6speedonline.com/forums/...ml#post2967798
https://www.6speedonline.com/forums/...ml#post2950088
https://www.6speedonline.com/forums/...ml#post2953256
https://www.6speedonline.com/forums/...ml#post2890671
https://www.6speedonline.com/forums/...ml#post2900491
https://www.6speedonline.com/forums/...ml#post2905706
