Built and installed my own gt2 mod kit with instructions
Old 08-09-2016, 09:48 PM
breakfast's Avatar
breakfast is infamous around these partsbreakfast is infamous around these partsbreakfast is infamous around these parts
anyone had any premature clutch wear with this mod?
ive seen it mentioned here and there...sitting around 2 yrs since I did this mod and all seems to be ok with the dgreen bracket and rod.
but my clutch has recently started to slip. :/ around 70k miles daily driven...so this may be considered "normal" . Im not sure yet.
edit: FYI my slave blew out when I was uninstalling everything. With the dgreen setup I was using the OEM clutch, pp and flywheel.
I measured the rod I had(From dgreen) and its 96mm...and looks awfully similar to the Mitsubishi rod mentioned earlier in the thread.
I didnt keep my stock rod...and want the car on the road.
Entertaining a shim/washers to bring the slave a bit closer to the case. Thus making the rod "longer".
  #137
Old 09-22-2016, 11:04 AM
breakfast's Avatar
No idea how my original held 2 yrs.
Was just bleeding and slave blew out.
Dgreen 96mm rod.
764 pp
Gt2 disc
Oem dual mass
Sachs throw out.
I'm going to see about having a custom longer rod made. The slave sits a good 9mm away from the trans.(Even with 2.5mm spacer I used ) That's too much to make up with such a short rod.
  #138
Old 09-23-2016, 05:34 AM
32krazy!'s Avatar
Dgreen 96mm rod.
764 pp
Gt2 disc
Oem dual mass
Sachs throw out.
what do you mean it sits away from the trans 9"? it should sit flush on the trans at the mount and be flush up against the clutch fork. mine has to be pushed in forcefully when bled since it contacts before the slave is fully seated. a stock rod is 102mm i believe
  #139
Old 09-23-2016, 09:32 PM
breakfast's Avatar
9mm ..not inches.
The slave sits flush against the mount..and the fork. Mine had to be pushed in to mount as well...but the slave still has a gap between it and the trans case(the 9mm)...
With the 96mm rod ...its not long enough in my experience. And others in this thread seem to have had issues too. The slave piston pushes too far and pops the cover off. At this point the piston has pushed too far out of the bore. With an oem clutch set up its not far enough to cause a leak, but its operating beyond what it should. As your clutch wears down it can then start to become more of an issue.
When I uninstalled it to do work. It puked its guts out upon unbolting the bracket. (Also mentioned by someone else in this thread when running 92 or 96mm rod lengths).
Upon installing and attempting to bleed a new slave. It immediately blew the cover off. I salvaged it, made my own longer rod.
Spending far too much time dealing with this...I never realized how much these brackets flex when you push the clutch.
  #140
Old 09-24-2016, 06:09 AM
32krazy!'s Avatar
9mm ..not inches.
9mm my bad. but i still dont understand were the 9mm is at. from the slave to the case? are you running the oem tapped case setup or a aftermarket bracket in the oem turbo hole?
  #141
Old 09-26-2016, 05:07 PM
breakfast's Avatar
why would I be posting in the built my own gt2 mod thread if I was running an oem taped case?
that said it didnt even dawn on me to go that route when I had my trans out. doh
  #142
Old 09-26-2016, 05:14 PM
32krazy!'s Avatar
why would I be posting in the built my own gt2 mod thread if I was running an oem taped case? that said it didnt even dawn on me to go that route when I had my trans out. doh
Having never considered anything but the oem setup for a gt2 i didnt grasp that you had a bracket setup. I now can see why it would be screwed up. Pull it tap dont look back
  #143
Old 10-03-2016, 07:06 PM
breakfast's Avatar
did you read the thread title/any information in this thread?
I think you might be lost. lol
The bracket mod worked perfectly fine for 2 yrs. its only after I pulled it apart to do the clutch that I encountered the issues I described. Running the longer rod now and all works well. Clutch up take has moved up a bit, but so be it.
Clutch actuation feels a lot better with the new clutch gear though. my stock pressure plate had cracks in 3 areas(not all the way through yet) and I can only assume led to the heavier pedal compared to now.
  #144
Old 06-05-2017, 08:29 AM
splitime's Avatar
splitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond reputesplitime has a reputation beyond repute
How is everyone's car doing on this setup these days?
I see a few of breakfast's notes, wondering if anyone else had any observations?
Looks like the car is due for its second accumulator and likely slave (fluid transfer) at 65k, thinking better pedal feel and reduction of complexity is a win win here.
  #145
Old 06-05-2017, 09:06 AM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
nice write-up. thanks.
  #146
Old 06-20-2017, 02:53 AM
Fab996tt2's Avatar
Fab996tt2 is a jewel in the roughFab996tt2 is a jewel in the roughFab996tt2 is a jewel in the rough
It's very interesting and thank you to share your experience.
I must do the work in a few days !
I'have a question: why do you remove away the power steering pump? What is the link with this work?
Greetings
Fabrice
  #147
Old 06-20-2017, 08:57 AM
VAGscum's Avatar
Greetings
Fabrice
You have to pull that back cover off the PS pump to remove the socket-like drive coupler that spins the dedicated clutch assist half of the PS pump. Unless you upgrade to a Tiptronic/GT2 pump.
  #148
Old 06-20-2017, 11:55 AM
Fab996tt2's Avatar
OK, but we are forced to do this procedure to install the GT2 conversion kit ??
  #149
Old 06-20-2017, 12:11 PM
VAGscum's Avatar
Yes.
  #150
Old 06-20-2017, 01:40 PM
Fab996tt2's Avatar
If I understand correctly, as I looked at the diagrams, I can only cut and plug these 2 hoses that you at the pump without remove the coupler ?
Can it stay like that or I must absolutely to change the pump ?
Quick Reply: Built and installed my own gt2 mod kit with instructions
