Built and installed my own gt2 mod kit with instructions
Old 06-22-2017, 07:37 AM
Fab996tt2's Avatar
Fab996tt2 is a jewel in the roughFab996tt2 is a jewel in the roughFab996tt2 is a jewel in the rough
OK, thank you, i have found a DIY for remove the coupler.
  #152
Old 06-26-2017, 03:42 PM
Fab996tt2's Avatar
I have remove the coupler of the Power steering pump !
And install all the think, and at the end, i destroy my slave, and the rod is falling down the clutch bell. GRRRRR
I managed to retrieve it after long time .......
Now is the question : why this damage ? The length of the rod ?? I have take the rod of 996TT !
I question Agency Power, but no answer !
I need your help
  #153
Old 06-27-2017, 03:06 AM
Fab996tt2's Avatar
Here are the stems that I have:
The one from above was annexed in a plastic bag (it is in aluminum).
The middle one comes from my 996TT (original, steel)
And the bottom one was on the slave cylinder (steel)
Which I have to use according to you, I am with an original 996TT clutch.
  #154
Old 06-27-2017, 10:56 PM
Fab996tt2's Avatar
This is the conversion kit I used, coming from Agency Power.
This kit fits on the original gearbox of the 996TT, without any other adaptation of the gearbox.
Here the kit :
  #155
Old 06-28-2017, 01:06 AM
Fab996tt2's Avatar
Originally Posted by 32krazy!
Not the way i would go but the rod should be a stock gt2 rod that comes with the slave
The GT2 rod is the shortest, so I do not think it will go, I'm wrong?
According to what I read above, it would be necessary to install a longer rod.
The rod alloyed to the Agency Power kit is approximately 127 mm.
  #156
Old 06-30-2017, 12:07 AM
Fab996tt2's Avatar
Well, if I measure the slave cylinder OEM 996TT with the OEM 996TT rod, I have to take the rod 127mm with the slave cylinder GT2 to have the same dimension.
I hope to receive today the new slave cylinder GT2 and do the editing to see if I'm fair.
Fingers crossed.
  #157
Old 06-30-2017, 01:28 PM
Fab996tt2's Avatar
Well, i have install the longer rod 127mm, and it work very nice.
I'm very satisfied.
  #158
Old 12-22-2017, 05:48 PM
Faster_Gun's Avatar
Faster_Gun is infamous around these parts
I just wanted to chime in as I am going through this job right now along with a Sachs 2.5 kit.
The OP mentioned the Motive bleeder to flush out all the Pentosin. Attached is my $2.00 solution. Considering we will not be res-using the green Pentosin cap this seemed like a good final use. These tire stems can be had cheap. I dont know the part number as I had one sitting around in my boost leak checker. Just drill the correct size hole and regulate your compressor at ~10PSI.
I blew about 4 master cylinders worth of some old ATE DOT4 Blue I had lying around and then continued to run pressure through the lines until the open end stopped sputtering. Recycle the blown fluid with your used motor oil.
  #159
Old 12-23-2017, 08:04 AM
Slider's Avatar
Beautiful... Simple & elegant.
TrackOne
08-20-2015 12:56 PM
Quick Reply: Built and installed my own gt2 mod kit with instructions
