Built and installed my own gt2 mod kit with instructions
Old 04-26-2012, 09:23 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Just ordering all the required parts so much cheaper to do it this way even in australia
Thanks for a wicked post
  #107
Old 04-30-2012, 10:04 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
Any update from others using the stock length/Orginal salve rod?
  #108
Old 04-30-2012, 10:29 PM
timccloud's Avatar
I have just ordered both I will post results once I have them fitted after I return home from my trip in a few weeks time
  #109
Old 05-01-2012, 08:13 AM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
Originally Posted by awdbiturbo1
How did you get the boot to fit the gt2 slave? I want to fit a cylindrical piece of aluminium into teh base of the slave where the rod comes out from then zip tie it to that. how did you do yours?
Btw i know dr jekyll is on quattro world but Vagscum how do you know Jason lol
I didn't attach the boot to the actual slave, I just attached the boot to the slave rod. The boot is big enough so the rod wont be able to fall into the bell housing. But it's not actually attached the slave.
  #110
Old 05-01-2012, 04:59 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
When I wrote this I used the turbos original push rod(as per the post) and it still works, and for me perfectly in terms of engagement point.
I daily drive my car and it's the stock clutch and pressure plate.
  #111
Old 05-08-2012, 08:58 AM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
I ordered parts from pelican parts. The slave cylinder failed and left me on the side of the road last night.
Gonna get a genuine Porsche one put in this time I think.
  #112
Old 05-08-2012, 09:09 AM
timccloud's Avatar
You need to buy the longer slave rod from dgreen78 for the conversion to work properly, slaves sold by pelican are same as oem.
  #113
Old 05-08-2012, 09:15 AM
ek9max's Avatar
You're right.
My tech just called and told me the slave is fine. And the pushrod is too short. I bought my braket from dgreen78. I don't know why he didn't sell me a pushrod too.
  #114
Old 05-08-2012, 09:48 AM
timccloud's Avatar
pleased I could help
Clutch engagement will be back up top of the peddle travel but at least you will have a lot more feel.
Im assuming you have a high torque clutch mind you unsure what it would be like with a stock clutch.
  #115
Old 05-08-2012, 09:51 AM
ek9max's Avatar
Apparently dgreen doesn't sell Rods anymore.
I like the feel of the stock rod. But I need something that I can drive my car....
Any suggestions where I can get a longer one?
  #116
Old 05-08-2012, 10:11 AM
timccloud's Avatar
um yes he does I bought one from him last week unless it was his last one ??
Otherwise get the Specs from Don and get one made up by a Machine Shop.
  #117
Old 05-08-2012, 11:09 AM
ek9max's Avatar
Originally Posted by Donkey
Hello,
Does anyone know if dgreen78 is still selling these? I'm very interested in the conversion but I cannot email this gentleman because of my low post count.
Thanks.
Can you pm me his email or phone number?
I can get my shop to fab one up. I just need the specs.
  #118
Old 05-08-2012, 12:36 PM
gearhead's Avatar
You could do it yourself when you get the length measurement, just buy some round bar the right diameter cut to length, grind off the burs, round the end, even dremel a mushroom cap in the end to help hold it in the slave.
But again with the stock clutch setup reusing the turbos oem slave rod works perfectly.
  #119
Old 05-08-2012, 12:38 PM
John@SpeedTech's Avatar
For anyone interested in avoiding this type of drama and multiple sourcing...The GT2 clutch conversion kits that we sell come with the slave rod modified to the proper length. It's a one stop shop with everything required for the conversion in one package.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
  #120
Old 05-08-2012, 01:06 PM
ek9max's Avatar
I intend to get one made once I get a hold of Dgreen to get some meassurements. Unless he overnights one to me.
Gearhead states that it worked great for his stock clutch setup. However, I would like to warn people that the stock turbo push rod DID NOT WORK FOR ME. It left me stranded on the side of the road last night. Good stuff.
I have a clutchmaster stage 3 with stock DMFW.
Quick Reply: Built and installed my own gt2 mod kit with instructions
