18G's too slow......now what?
#32
I can share a little of my experience going from 18g's to 20g's. The 20g's on pump gas perform similarly to 18g's on race gas. The upgrade is significant in cost however. I would suspect that if you have already done a clutch it will still cost you about 6K minimum for the hardpiping, IC's and various other tidbits you will need. Is it worth it? Every penny. I think the 20's are one of the best all around turbos for these cars and I've been fortunate to drive a few of the various setups around from K16/16g cars to GT30 cars. The spooltime is almost zero the power delivery is extremely linear relative to the power it makes. I wouldn't think twice about doing the upgrade. If you plan to run pump gas primarily you can tune accordingly and run 1.2bar all day every day.
#33
Hi Jane,
+1
Bobby's 2001 white 996tt was I believe the first one to be fitted with 20gs.. granted, he ported, polished, clipped the turbine wheel... and even extrude and honed the hot side.... that car gave a many nightmares... even the 30rs... but the owner was an elite in what he does... always pushing the envelope... thus the great results...
2001 996TT 3.6L and stock ECU
#34
+1
That's one of the cars i've been lucky enough to drive actually.
#35
In minnesota?
#37
Hows it running? U know there was a few hands in there before it came to MInnesota..
#40
I would agree depending on who tunes the car and whether or not its an off the shelf file or a custom file.
#42
I don't want to threadjack here, but what about lag on the 20g's ?, personally I like as much torque down low on the street. If I were looking to take the next step past 18g's, taking the torque down low into consideration (and I mean down low as possible, peak TQ under 4k), what turbo is going to give me this without completely sacrificing HP up high ?
#44
#45
EDIT: Just looked at your mods. The upgrade to 20g's is a no brainer for you!! Do you have an upgraded clutch too? If so, I bet you could have everything done including the switch to 20g's for about 3-4K (Hard Piping, Additional Fuel Pump, misc.)
