Forged vs low pressure cast wheels
God you don't have to take shots at Paul and Sean like that!
i heard they are going to C & C tomorrow.
Though not enforced, there are quality standards to govern the production of wheels. Some countries though, like Germany and Japan, have government regulations requiring aftermarket wheels to meet certain criteria and ensure proper fit. The United States has taken steps to establish guidelines but it will be some time before they can enact regulation of any kind. Consequently, all wheels are not made the same. The performance of an alloy wheel is a direct result of the manufacturing technique employed.
Gravity Casting
Gravity casting is the most basic process of pouring molten aluminum into a mold utilizing the earth's gravity to fill the mold. Gravity casting offers a very reasonable production cost and is a good method for casting designs that are more visually oriented or when reducing weight is not a primary concern. Since the process relies on gravity to fill the mold, the aluminum is not as densely packed in the mold as some other casting processes. Often gravity cast wheels will have a higher weight to achieve the required strength.
Low Pressure Casting (Avant Garde)
Low pressure casting uses positive pressure to move the molten aluminum into the mold quicker and achieve a finished product that has improved mechanical properties (more dense) over a gravity cast wheel. Low-pressure casting has a slightly higher production cost over gravity casting. Low pressure is the most common process approved for aluminum wheels sold to the O.E.M. market. Low-pressure cast wheels offer a good value for the aftermarket as well. Some companies offer wheels that are produced under a higher pressure in special casting equipment to create a wheel that is lighter and stronger than a wheel produced in low pressure. Once again in the quest for lighter weight, there is a higher cost associated with the process.
Flow-Forming or Rim Rolling Technology
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel without the high cost of the forging. Some of the special wheels produced for the O.E.M. high performance or limited production vehicles utilize this type of technology resulting in a light and strong wheel at a reasonable cost.
Forged
The ultimate in one-piece wheels. Forging is the process of forcing a solid billet of aluminum between the forging dies under an extreme amount of pressure. This creates a finished product that is very dense, very strong and therefore can be very light. The costs of tooling, development, equipment, etc., make this type of wheel very exclusive and usually demand a high price in the aftermarket.
The Forgestar F14 Flow Form wheel has been extremely successful as it's a great wheel for the value. It's not has BBK Clearance, but its a strong, light weight, quality wheel. They're also a fraction of the cost compared to other flow formed wheels such as the BBS CH-R, ADVAN RACING, etc. I'll shoot you over a PM with more details!
- Alan
Gravity Casting
Forged
- Alan
I will be there you big bully picking on a 24/18 car. Oh well I will see what she can do.
I am teaching my Jui-jitsu/self defense course tonight so I may be too beat up to get to Uptown by 8...I brought in a straight up boxing coach so I may end up training late.
Back to the OT, what do you guys know about this flow forming technology?
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
PenguiN
09-15-2015 11:44 AM
Vellano Wheels
Other British Cars
08-21-2015 03:22 PM
ModBargains
08-20-2015 12:28 PM
