Car overboosting with Greddy Profec II
Hi Guys,
I have been wrestling with this problem for two weeks now. Here is a short summary. Car was rock solid before with this exact setup.
Greddy ProfecII, Autometer boost gauge and GT800 package from EVOMS.
1) Two weeks ago, noticed a surge in the car on 91 octane.
Car was set to 17 lbs boost on low setting on EBC, but was boosting to 21.
2) My Autometer boost gauge seems to work as before (showing 21 lbs), the Profec however, seem to see 4.5 lbs less boost.
here is what I have done so far.
1) Both my Autometer gauage and Greddy seem to read 0 when I open the back (we are almost at sea level in San Diego).
2) I attached an air hose with boost gauge to the back of Greddy and at 30 lbs it read spot on, my air-compressor does not operate accurately below 25 lbs.
4) using a vacuum pump, I have tested the integrity of the boost lines. NO APPARENT LEAK.
3) We are checking the waste-gates on my 3071s and planning to install a manual boost gauge right before the input to Greddy.
I am about to buy anther Greddy Profec II to just eliminate that piece as well.
So all you Oracles help this near mortal here, any and all suggestions are most welcome.
Over-boosted and Frustrated.
-Arman
-Arman
Not much advice, except why don't you use the factory boost valve? Are you changing boost with your gas type?
be careful until you figure it out, not worth blowing the engine.
-Arman
changing the greddy is not the answer...
whats your set gain set up at?
to really see the pressure your car is doing why dont you run a durametric on it... then compare...
another thing to do... pressure test from the turbos... but you need a accurate gauge compressor... and pressure to 20 psi lets say... then have someone look at the greddy and see what it will read out...
also, are both auto meter and greddy tapped in at the same location?
Boost leak? did you do a boost leak from the turbos?
2001 996TT 3.6L and stock ECU
>> Currently 38%, 20%, 850, and 140 for max boost
>> but boosting to 18 PSI
>> The weird thing is Greddy Shows 138 as max boost reached.
>> I do not have a Durametric, but I guess I can always buy one.
>> This is the next step, I have asked a friend who is a certified Porsche tech at local dealer to help me with this.
Again Mark thank you for all your suggestions and useful tips.
-Arman
This is what my mechanic thinks too, however, what bothers me is that Greddy is seeing X and Autometer sees X+delta, no if Mark is correct and both are fed from the same source why the difference.
It is just weird.
at idle on vacuum it should show -.60 to -.67... so you probably have some boost or vacuum leaks... boost test from the turbos will show everything... assuming you do it right and diagnose the issue(s).
How about my boost gauge showing -13/14, is that one ok?
-Arman
I have no idea... btw who installed the kit? or did you buy the car that way...
I didnt know Evoms sold that kit with a greddy... Usually they offer it on the bigger motor build packages.. is this something you added afterwards?
BTW, thank you for all your suggestions.
-Arman
I believe my gauge uses in.Hg which with the use of google unit conversion gives -6.39 PSI as Mark mentioned.
Ok them why don't you send the car to Alex to figure it out instead of having different people work on your car ? The more hands in your motor the worse it will be in the long run, and while your car is there you can do the rest of the work
