Help: Intercooler problem Question
Old 10-11-2010, 09:28 PM
Prche951's Avatar
well lesson is, pressure test the IC's yourself even if they are secans.
Heck, all I did was put the shop vac on one end with a rag to seal it and my hand on the other end and I could clearly hear the noise of air wooshing out of the IC through the cores.
  #32
Old 10-12-2010, 08:45 AM
what brand are these things?
#TeamAIM
  #33
Old 10-12-2010, 08:58 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Hey Dennis this is not a JK any more,sorry for your project.
  #34
Old 10-12-2010, 09:21 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
Whats the likely hood that the stock factory units suffer from the same leakage issues?
  #35
Old 10-12-2010, 01:03 PM
Prche951's Avatar
good question. I have a spare set, I can check. I also have a set of GT2's I can check. Earl can check his knew ones as well.
  #36
Old 10-12-2010, 01:35 PM
chances are - they leak. tabs that hold the end tanks on tend to loosen a bit under higher boost and create leaks. i have not tested mine - but my friend with a Leagcy GT which has a top mount intercooler with plastic end tanks like ours had isses with the stock unit leaking at higher boost.
#TeamAIM
  #37
Old 10-12-2010, 01:46 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
I've checked the new ones (997.2) and my old GT2/997.1 cores when they went on. At just over 25 psi, they held steady for 5 minutes, at which point I released the pressure. In both instances the cores were lightly used (<500 miles) before I got them. Even though I haven't had issues, I always pressure check from the turbos whenever I mess with stuff in that area. Particularly important as these cars have some age on them now.
04-28-2022 12:38 AM
nlakind
11-06-2015 10:15 AM
turbotuner20v
09-11-2015 12:02 PM
pogeybait
08-28-2015 04:47 PM
gulf gt
08-27-2015 10:27 AM
Quick Reply: Help: Intercooler problem Question
