Europipe HP capabilities
What are the maximum HP capabilities of Europipe Exhaust? Cats included.
Did anyone have restriction problems using this exhaust on high hp cars?
Thank you
Thank you
I had a EP loud (76mm) with cats deleted. I have just about every bolt on mod possible: Gt30 turbos/headers/external 44MM wastgates, 5inch IC's w/ dvs mounted on them, full proto fuel system (dual pumps, rails, lines, 83 lb injectors) full blow throgh intake system, pretty much the works except maybe alphs turbos or the slightly larger Precision turbos that Powell runs.
Until recently I kept my exhaust because I just LOVED the sound. And yes it is top quality. However it was the restriction point on my set up.
By going w/ a full 3inch set up (BBI) my car spools much faster and probably makes another 40 hp.
The 76 mm EP will not be a restriction point until you get over 600 whp.
best is catless of course..
2001 996TT 3.6L and stock ECU
It is unlikely that you'll gain 40 hp with going from a 70mm catless exhaust to a 76mm ( 3 inch ) catless exhaust.
EP Stage 2 quiet. I later tried every possible exhuast in an attempt to
get better sound, more power, less drone, cooler looking bends, etc, etc.
