Wastegate Actuator noise/rattle
#31
Frank
#32
Do they rattle when you use your hand to try to move the wastegate, or is the rattle when you are driving:
1. off boost
2. On boost
3. Engine Running or Not running.
I ask because the wastegate inside the turbo is a ceramic dis that is Riveted onto the crank arm. It is not a tightly riveted, it allows the disc to float a little so it makes a good seal over the wastegate outlet form the housing. This disc can rattle when there is no tension on the wastegate from the actuator. When the wastegate open under boost the ceramic disc can vibrate a little if becoming worn. It should not vibrate/rattle when off boost.
If the ceramic disc rattles off boost then there is no tension forcing the disc onto the wastegate hole.
Normal cause is seized partially closed wastegate or no tension form the actuator. Ie no preload on the rod.
Which is it Alex?
Frank
#33
I've start to hear this sound a few moths ago, at 1600-1800rpm I hear a rattle. When I hit with the finger the rod from the wg it rattles. They tested the wg and is working fine so what can i do to get rid of this rattle?
I was thinking at the exhaust part of the turbo...
#34
Are you also sure that the actuator is fully closed. I know you say its been set up, but the starting point should be with full closed wastgates. ie the ceramic disc should be tight over the waste gate outlet hole sealing it. If the ceramic disc is even 0.5mm from fully sealing the hole the disc will float ie it will be free to move on the rivet that it is connected to the arm with.
If you are not sure, you can get to the waste gate ceramic disc with just the exhaust off. check that the disc is pulled tightly over the hole/outlet.With the actuators set up correctly( correct pre-load) you should not be able to spin the disc around it should be fully pulled up to the face of the wastegate outlet hole.
Frank.
#36
Alex, that should not rattle with pre-load applied. Are you sure the sound is not traveling from behind that arm inside the Turbo??
I then have to ask, are you sure there is pre-load on the arm, there should be. Under load the arm cant move to make a sound its beimg pulled very hard so cant rattle. It will only rattle if worn when not under any pre-load.
The only thing looking at the picture is they washer at the back of the arm could vibrate even when pre-load is present.
These arms are riveted to each other. That arm can not be riveted tight as it has to have clearance to move, so a packing washer is placed at the back of the arm and metal is peened over so stop the washer form coming of. If they are slightly worn the washer could rattle. I cant see this is a big problem. To prove a theory, pack the back of that arm and washer with high temperature copper grease and see if that stops the rattle for a while.
Frank
Frank
#39
Hi Alex,
TBH its probably at the stage where anyone would need to be with you to see for them selves. Try making a video for us to see a bit more.
If you are getting the required boost with the turbos set up correctly, not dropping boost or over boosting, no codes or any other reason to suggest a fault then it might just be a case of an annoying rattle. Try the HT copper grease, not for a long term fix but to prove the rattle is or is not from the arm in the picture. If a little copper grease helps to start with I would suggest the rattle is causing no harm and it might just be a case of "Live with it". It could be one of those rattles that will go away on its own.
Who knows. unless I was there I Cant think of another way to suggest for you. I have a idea on how I would continue, I'm just not sure just how much you have done/tested.
I will keep reading and see how you get on.
Frank
Frank
#42
They just weld it.
#43
At least you still have the heat shields. Mine corroded so badly they fell off. I saw one bouncing across the road in my mirror.
#44
The new bad news is that my hydraulics from the spoiler started to leak
#45
Is that bad news or the just excuse you need to bin the hydraulics and have a better spoiler fitted or even the fixed wing option
