Garrett Ball Bearing turbos????
Old 03-08-2005, 08:30 PM
K24madness's Avatar
K24madness is infamous around these parts
Old subject that I hope has new answers....
We all know the performance potential of the Garrett turbos. Lots has been said about the short life spans of these turbos. What has been done to solve the problem?
What do you have and how many miles with or without failure?
THIA
Old 03-08-2005, 09:27 PM
Zippy's Avatar
Re: Garrett Ball Bearing turbos????
Originally posted by K24madness
.... Lots has been said about the short life spans of these turbos....
Are you talking about Garrett modified KKK non ball bearing turbos. AKA my turbos???
Old 03-08-2005, 09:46 PM
K24madness's Avatar
No.
I am talking about the ball bearing turbos.
Old 03-08-2005, 11:32 PM
I thought that the modified kkks have the ball bearings inside( ie. garetts internals)???
its usually a k16 hot side and anything from k24 all the way up to k27 cold side.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 03-08-2005, 11:40 PM
trojanman's Avatar
Welcome to the OC, bitch!
trojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant future
One of my best friends works for honeywell turbo technologies (aka Garrett). They make nice turbos, but by his admission KKK are better for Porsche applications.
This statement is backed up by my local independent tech.
Old 03-08-2005, 11:49 PM
K24madness's Avatar
In what regard? Life span?
Old 03-09-2005, 12:03 AM
Yes but these hybrids and or modifed turbos are very different and(usually) specific to the ( GIAC ECU) application. its a combination of both- Garett and KKK technology. they use the KKK housing cause they fit the stock headers...
9.66
click to view
Old 03-09-2005, 07:21 AM
PorschePhd's Avatar
Any car that has a map and EFI will be specific with the programming and the turbos. Few cars can you just slap a turbo on and expect it to work. Only CIS can you get away with that and only so far.
Turbos will last if you take care of them. Proper cool downs....
Old 03-09-2005, 10:44 AM
K24madness's Avatar
Thanks Stephen.
I understand that all turbos must be taken care of and fed the proper fuel. All thing being equal do the ball bearing cartridges have a resonable life span? Any guess as to the ratio? 1/2 the life of the KKK?
Old 03-09-2005, 02:07 PM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
You can get Garrett ball bearing turbos to work quite well if you change out all the factory plumbing. It actually yields some impressive results. Just ask Todd @ Protomotive.
Old 03-09-2005, 03:33 PM
u mean the rubber hoses.... what about the metal splitter going into the turbos( blue hose with metal from FVD).
9.66
click to view
Old 03-09-2005, 04:05 PM
Hamann7's Avatar
Porsche Fiend
Those are all re-done to hard piping as well.
Old 03-09-2005, 06:41 PM
trybaljedi's Avatar
trybaljedi is infamous around these parts
With sufficient lubrication and proper cooldown procedure, I dont see how longevity would an issue.
trybaljedi's Avatar
On what basis?
Old 03-09-2005, 08:31 PM
K24madness's Avatar
Has ANYONE with ballbearing turbos had a failure ????
(non fod related)
Kind of supprised since so much has been speculated about durabilty.
Quick Reply: Garrett Ball Bearing turbos????
