New 60-130 best...
Old 12-14-2010, 03:56 PM
ttboost's Avatar
Originally Posted by 2muchtime
what plenum are you going with? IPD
Maybe I mis-spoke. I have removed the portion of the intake plenum related to the intake piping (right after the airbox, including the airbox). I am still going to utilize the stock plenum after the throttle body, for now. I am just upgrading all the piping BEFORE the throttle body, including IC's.
  #32
Old 12-14-2010, 05:31 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
TTBoost-- who tuned your car?
  #33
Old 12-14-2010, 05:45 PM
MBailey's Avatar
Mike,
Your car will like the intake piping!
When you get that stock crap out (probably with a hacksaw!) you will not believe how tortuous and restrictive it is. Your car will pull noticibly harder up top if your tune can take advantage of the extra air. My turbo spool was also noticibly louder... My mile speed was significantly better with this mod.
  #34
Old 12-14-2010, 05:58 PM
ttboost's Avatar
Yeah been wanting to do it for a while. Just waiting for the right opportunity(s). Actually have all the stock crap out as of last Saturday. Just forgot the silicone couplers at home, so couldn't finish it. Tony (EPL for LinKs) wants to redyno after the piping just to see the difference. I figure I should pick up a tenth or two 60-130?
  #35
Old 12-14-2010, 06:34 PM
MBailey's Avatar
That might be conservative...
  #36
Old 12-14-2010, 07:17 PM
ttboost's Avatar
Keepin my expectations low...
  #37
Old 12-14-2010, 07:26 PM
gt2rs6's Avatar
gt2rs6 has a spectacular aura aboutgt2rs6 has a spectacular aura about
please keep me posted on this one!!.. ill be right behind you with this mod
  #38
Old 12-14-2010, 08:43 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
i am really interested as to how the intake piping affects lag. I think it was USP that showed a lot of before and after intake piping dynos on some alpha 30's, but I haven't seen many dynos of alpha 28s.
You can see my alpha 28 tiptronic dyno here https://www.6speedonline.com/forums/...ng-700-hp.html
I really want to know if mine is spooling up as quick as yall. I have custom silicone intake pipes, but due to the tiptronic being a fat pig, the piping gets crunched in a few areas...I want to know how much this crunching is hurting me (if so, BLOW THRU time).
  #39
Old 12-15-2010, 06:51 AM
AlphaDog28's Avatar
AlphaDog28 is a splendid one to beholdAlphaDog28 is a splendid one to beholdAlphaDog28 is a splendid one to beholdAlphaDog28 is a splendid one to beholdAlphaDog28 is a splendid one to beholdAlphaDog28 is a splendid one to beholdAlphaDog28 is a splendid one to behold
I am at peak torque around 3-400 Rpms faster than you.
  #40
Old 12-15-2010, 08:55 AM
AlphaDog28's Avatar
So you are replacing the Y-pipe and the intercoolers, not the fresh air inlets that feed the turbos on the back side of the motor?
  #41
Old 12-15-2010, 08:59 AM
ttboost's Avatar
I am replacing EVERYTHING, BUT the plenum behind the throttle body.
  #42
Old 12-15-2010, 10:33 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
what parts are you putting on? mfg is what i mean
  #43
Old 12-15-2010, 01:15 PM
ttboost's Avatar
Evoms piping, custom Y pipe and custom IC's. Can't say much more than that right now...
  #44
Old 12-15-2010, 01:43 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
did you have a dyno run before these new mods? be interesting to see the gain difference
  #45
Old 12-15-2010, 03:46 PM
ttboost's Avatar
Yeah we have baselines to go from. It's too much work to do a mod at a time, so I'll do all the mods and baseline again.
Quick Reply: New 60-130 best...
