K24/18g DIY upgrade
K24/18g DIY upgrade
I see alot of companies offer the k24 18g upgrade
anyone have the partnumbers needed to upgrade a standard k24 into a k24/18g?
http://cgi.ebay.com/ebaymotors/Turbo...Q5fAccessories
http://cgi.ebay.com/Turbo-Compressor...item4aa2c9a8b1
what types of machining methods are necassary?
I'm not trying to be cheap, but i'm a DIY type of guy, and i have access to machine shops, just curious if these would work?
any other peices parts required?
http://cgi.ebay.com/ebaymotors/Turbo-Compressor-Wheel-Mitsubishi-TD05H-TD06-18G-_W0QQcmdZViewItemQQhashZitem588b32ee8cQQitemZ38029 2492940QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
http://cgi.ebay.com/Turbo-Compressor-Wheel-Mitsubishi-Lancer-EVO4-9-18G-/320558704817?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item4aa2c9a8b1
Best leave it to the experts.
frank
Definitely not a DIY thing. The install and injectors and all that is good to go on your own. Actually machining, balancing, building, and testing your own turbos would be nearly impossible without all of the proper tools and machines. Not to mention the years and years of knowlede R&D and trial and error that goes into these builds.
That being said, if you were to DIY and get it right and correctly working, well, huge props for the sheer cojones to try it. you should get a medal or something if you ppull it off.
Anyway, don't. Leave it to the pros. Get your k24s sent out and upgraded for $1200.00 and have the piece of mind that they're not going to expload onn you.
the compressor has to be balanced perfectly on the shaft. if it is not, the fins can hit the housing break and get blown right through the TB into the engine. its worth paying Blouch or Forced Performance for a quality rebuild.
#TeamAIM
#TeamAIM
trust me you dont wanna do it.. last member tried to get them done thru someone that never did it before and damaged the turbos... they ended up scrapped up....
good luck
markski
good luck
markski
2001 996TT 3.6L and stock ECU
Feelgood MD
03-24-2016 10:35 AM
ECS Tuning - VW
09-02-2015 10:03 AM
