HKS EVC 6 problem...
Hello ! and I apologize, I awfully know English language
I have a problem. This problem HKS EVC 6. More precisely сonnection to Porsche DME 7.8. (996turbo, tiptronic s, 2001 internal WGs)
I long searched pinouts & plug diagram's but haven't found. To me very necessary two DME PIN. 1.the engine speed sensor 2.Throttle (pedal) position sensor. DME has 5 connectors and much PIN where to search ? Or at least give "pinouts & plug diagram" for Porsche Motronic 7.8.1. My E-Mail: Freaked911@hotmail.com thanks...
but... Certainly, it is better if tell very in detail
Big big Thanks !
Big big Thanks !
You need sheet 12A&B from the wiring diagram for the 01. I have the pinout for CU DME M338. Speed Sensor Signal pin 78 ground pin 20. Throttle Valve Pins 21 & 23.. Ah hell - I'll send you the link...
the same Obstacles i faced when i installed the hks. I realy dont remember but i think i took the green/violet from the obd port wires for the engine speed sensor. That was the hard one. the other wire i took from the dme i found it in a diagram it was easy.
I hope i can help more..
If u feel that its very hard to find the wires i will open the ecu and obd port to help u.
#TeamAIM
#TeamAIM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
KINGS POWER
04-04-2008 07:00 AM
