strong hesitation
strong hesitation
i was faced with some strong hesitation yesterday when i took the car out for a ride, the hesitation comes when i accelerate fast, anyway i went back home and connected my durametric and this fault code came up:
P1241 Porsche Fault Code 154 - Injector Valve Cylinder 3 Open Circuit.
Any Ideas??
Any Ideas??
Open circuit means usually a wiring harness is loose or disconnected....
thats as far as I can say...
markski
markski
2001 996TT 3.6L and stock ECU
Frank
P1241
154 Fuel injector, cylinder 3 - open circuit
Diagnosis conditions
Engine running
Battery voltage greater than 7 V
Possible fault cause
Fuel injector (coil) open circuit
Open circuit in wiring
DME control module
Affected terminals
Terminal III/15
Open circuit causes the fuel injector to be continually closed.
Diagnosis/troubleshooting
Note!
Work instruction Display OK If not OK
1 Check fuel injector
♦ Remove connector of fuel injector
Connect special tool V.A.G.
1315 A/1
1315 A/1
Measure resistance at special
tool V.A.G. 1315 A/1
11 - 13 Ω
11 - 13 Ω
(at 20 °C)
Step 2
Replace fuel injector
End
2 Check wiring harness for
open circuit
open circuit
Connect special tool 9637 to
wiring harness (DME control
module plug)
module plug)
Repair wiring harness
End
Measure resistance between
special tool 9637 Pin III/15 and
fuel injector plug Pin 2
0 - 5 Ω
⇒ Step 3
0 - 5 Ω
⇒ Step 3
3 Replace DME control module
⇒ Step 4
4 Perform adaptation ♦ Switch on the ignition
Wait one minute
Do not press the accelerator
Switch off the ignition for at
least 10 seconds
least 10 seconds
Read out the fault memory
End
Hope that helps a little.
Frank
Frank
10-07-2015 01:55 PM
