Best looking wheels on a 996 Turbo
Old 04-07-2016, 01:19 PM
MotoJB's Avatar
MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !MotoJB Is a GOD !
Originally Posted by Wheel Dynamics
For the record the 245/35/19 and the 295/30/19 would be a closer match to the factory specs vs. the 305 according to my calculations....
When I say this I mean in relation to each other, but of course this is a taller set-up.
Wouldn't that make the rear taller than the front? I thought that was a no-no...
  #992
Old 04-07-2016, 01:30 PM
MotoJB's Avatar
SO many variables and I'm confused. Maybe a better, more straight-forward question for all of you more in the know than me...
What 19" tire and rim combo would you suggest?
19x8.5 & 19x11?
Tire sizes?
Thanks for the help here.
  #993
Old 04-07-2016, 01:39 PM
hdp951s's Avatar
hdp951s is a splendid one to beholdhdp951s is a splendid one to beholdhdp951s is a splendid one to beholdhdp951s is a splendid one to beholdhdp951s is a splendid one to beholdhdp951s is a splendid one to beholdhdp951s is a splendid one to beholdhdp951s is a splendid one to behold
Just my experience:
I run 19 x 8.5 and 11 with 295/30 and 245/35. Works well with no problems.
  #994
Old 04-07-2016, 02:00 PM
MotoJB's Avatar
Originally Posted by hdp951s
Just my experience:
Thanks...but doesn't that make the front shorter than the rear? I thought that was a no-no with AWD?
  #995
Old 04-07-2016, 02:18 PM
pwdrhound's Avatar
Very few people have an understanding of how the rather simple 996TT AWD system works. The ONLY way the system can transfer even an ounce of torque to the front wheels is if the rear wheels are rotating faster than the fronts. If it's the other way around then the front wheels are simply providing driveline drag into the gearbox through the viscous coupler...
  #996
Old 04-07-2016, 02:25 PM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
This is what I am seeing for the S-04 that I would get
305/30/19 - D = 26.3 Revs = 793
235/40/19 - D = 26.4 Revs = 788
That is pretty much spot on
  #997
Old 04-07-2016, 03:25 PM
JimTT's Avatar
JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !JimTT Is a GOD !
Totally agree with this.
This looks like a good match.
  #998
Old 04-07-2016, 03:39 PM
Road King's Avatar
Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !Road King Is a GOD !
I think it's pretty straightforward.
The front tires must be taller (less revs per mile) than the rears, or the AWD system can't transfer torque from the rear wheels to the fronts. Correct?
  #999
Old 04-07-2016, 04:05 PM
pwdrhound's Avatar
Correct. This is also the reason that Porsche states that torque transfer to the front increases gradually as the speed of the vehicle increases due to the fact that the speed difference between the wheels gradually becomes greater. Also, if you get slippage of the rear wheels, the speed difference becomes suddenly greater and as a result more torque is quickly transferred to the front wheels.
Using the same logic, obviously if your fronts wheels were a little smaller than the rears, then drive line drag would increase as the speed of the vehicle increased. Obviously is is the exact opposite of what you want.
  #1000
Old 04-07-2016, 04:17 PM
Road King's Avatar
Thanks pwdrhound, totally makes sense.
So, in the end, it's irrelevant when someone quotes the ''it's within 3% tolerance'' and everything's going to be great.
If the front tires *are* shorter, the AWD system isn't going to work as designed and the car will basically act as a RWD car. And there's the potential that the drag created by the shorter front tires may cause issues/damage to the viscous coupling. But best case, the AWD isn't going to work properly.
  #1001
Old 04-07-2016, 04:38 PM
pwdrhound's Avatar
Yes, the mythical internet 3% you read about (which is not a published number by Porsche anyway) works both ways. Only one is correct however. You want to keep the wheel diameters relatively close (fronts slightly taller) in order to keep the viscous coupler from overheating. The greater the difference in diameters, the greater slippage you have between the input/output side of the viscous coupler which leads to more heating of the viscous fluid.
  #1002
Old 04-08-2016, 10:05 AM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
Well that sucks. There is no PSS setup that will work where the fronts are taller than the rear's unless you do the 225/40/19 and 295/30/19's and then it's 797/799.
Would you guys prefer less front end grip (225 vs 245) and AWD, or RWD with more front end grip (245)?
Which is the lesser of two evils?
  #1003
Old 04-08-2016, 10:28 AM
MotoJB's Avatar
Well, this is interesting...I went with the following Yokohama AD08R tire combo on my current 18" setup. I figured I'd be completely fine going with stock tire sizes of 225/40/18 and 295/30/18.
Tire Rack however, shows my front and rears to be the exact same height...with identical rev's per mile. Any issues/problems with this??
  #1004
Old 04-08-2016, 10:34 AM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Stock vs. 19" OD:
225/40/18 25.1
295/30/18 25.0
225/35/19 25.2
235/35/19 25.5
245/35/19 25.8*
295/30/19 26.0*
305/30/19 26.2
305/25/19 25.0 NLA (No longer available)
315/25/19 25.2
Many will chose to go with Blue option most of the time since they are electing to enter into a 8.5" front and the 225/35/19 would be a bit of a stretch even-though it would be a good match with the 315/25/19.
Most also are veering away from the 315/25/19 since there is a lack of choices available at this time, years ago Michelin PS2, Continental, Toyo T1R, Nitto Invo and Falken 452 were all pretty available but we are down to Nitto Invo and who knows how long that would last. The 305/25/19 was a great fit but those have not been manufactured for a very long time and even if you find old stock they are sure to be out of date.
IMO, the 245/35/19 and the 295/30/19 is the optimum sizing for the C4, C4S and Turbo models that run 19x8.5 and 19x11 set-ups.
But do your own homework to satisfy your needs...
  #1005
Old 04-08-2016, 10:56 AM
Road King's Avatar
So in this example, would the AWD system be able to transfer torque rear to front, would it cause drag, or zero effect?
Quick Reply: Best looking wheels on a 996 Turbo
