Best looking wheels on a 996 Turbo
#1066
+1 on stock twists. They look great when darkened up too. Thats why I like the factory GT silver on the ones that the turbo S came with.
#1070
Wow! Car looks amazing Dan! The wheels are the business against seal gray. Glad you like them. High quality forged lightweight wheels are an often overlooked item but should be a part of any high performance set up.. Cheers!
#1071
Thanks again John. You are definitely a great source for track information and great to buy from (super quick easy deal). Appreciate your contribution to the forum.
For reference to others , I'm low on KWv3's 120mm135mm. Front rad mod (fwd 1"). Slight fender roll. Tires are 235/45 26.4" and 295/35 26.2 " no rubbing. Slight rubbing on full lock. I'll get some 255/315's when the tires are cooked. I believe the wheel offsets are 47F 40R. I run minimal camber for tire wear.
KW sent me some replacement springs on warranty since the original springs on max ride height is well below their published range. I'm going to raise 10mm as my front scrapes too much.
#1072
