K16 billet hybrid... How do you like yours
#31
#33
Now I think I remember! This is the configuration that ran 197 mph at the TX Mile. 670 whp is certainly capable of going that fast. I believe they ran about 192-193 at the 600whp level...
#37
I suggest against it, you are not doing the turbos justice. Might as well be running 30r's with stock injectors...
#38
Yeah "TECHNICALLY, stock injectors are maxxed with just a flash. A 5bar just gives you a little bit of room. I'd say 500whp is max, and still be safe? You can make more power, but your cushion goes away very quickly.
#40
$500-$600 for a set? I have 58lb'ers. Most jump right for 72lb'ers. Once you have a tuner, they will recommend what you need, based on your intended use. Your tune needs to reflect your injector size.
#41
Where can I get injectors, why are they quoted in lbs as opposed to CC flow? What horsepower are you running? What can 58lbs'er take hp wise and what are the stock injectors??
#42
Any tuner/vendor can get injectors. "LB" per "CC" is a personal preference I guess. Be very careful about which injector you get as some cannot be run with a 5bar. I guess it's obviously better to have the right size injector as to not need a 5bar. I am right about 600 wheel and am out of fuel now. Any mod I do now requires an injector step-up as well as an additional fuel pump. Not sure how big stock injectors are?
