JIC Cross Suspension Installed - Rear Clunking
I wouldn't say it's defective. My personal opinion is that the coilovers suffer from poor build quality. They didn't always clunk. It happened maybe a few hundred miles after I started driving it.
- I literally threw a thousand or two trying to solve the problem. Maybe your problem is not the shock? maybe it's something hitting a control arm?
All I know is I replaced with KW's, RSS upper control arms, RSS lower control arms, ERP tie steer rods at the same time.
No knock, clutch, rattle anything.
I still have what looks like the oem lower control arms, and on the rear drivers side I seem to have a slight amount of play if I twist it left to right. I wonder if that could be my problem.
before changing over to the PSS9 and the RSS, did you check your lower control arms? did you have OEM or aftermarket lower control arms when you were running the JIC's?
Mackchacha
07-09-2019 11:03 AM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
ECS Tuning - VW
08-20-2015 03:07 PM
