What size tires for 19 x 8.5, and 19 x 11", any problems with clearence w/
With wider 19" and 315x25 you may have to roll the fender lips on the rears. I had a very slight rub on the inner left rear fender liner at full compression which I fixed with 5mm spacers.
Main issue as always is the wheels themselves and what offsets.. As covered in many other threads you pretty much have to go 235/35 and 315/25 for 19s to make sure your tyres are the right size to avoid front diff damage. I run this combo Michelin PS 2s on BBS CH-Rs on 8.5 front and 12 back and have zero problems with rubbing on a lowered car. The rear tyre is actually probably a touch better suited to and 11 inch rim as well.
COBB Tuning
11-09-2015 08:02 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
ModBargains
08-20-2015 12:28 PM
