is there software for using a light flywheel?
Old 03-17-2005 | 01:21 AM
phillym5's Avatar
phillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to beholdphillym5 is a splendid one to behold
My revs drop down too quick, and im looking for some softare to fix that. I have FVD in there now.
josh.
Old 03-17-2005 | 08:27 AM
mpwrmodena's Avatar
mpwrmodena is infamous around these parts
Raise your rev limiter to compensate for your flywheel. Since it isnt damperd you must pump the clutch peddle and give it more gas then normal to get moving. A heavy stock flywheel remains spinning when you are stopped. Lightweight flywheels tend to chacter and be difficult to get moving when at a dead stop because they stop spining.
-Daniel
Old 03-17-2005 | 08:35 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Re: is there software for using a light flywheel?
josh.
shift quicker. That is the whole pupose of a lightweight flywheel, imo...
Old 03-17-2005 | 08:40 AM
phillym5's Avatar
Thats not what im talking about.
Example. Im at a stop sign, I just start to go but someone cuts out in front of me, so i hit the brake and push in the clutch. Revs drop to quick. And can some times stall. Even from a blip of the throttle just sitting there, it will sometimes stall.
josh.
Old 03-17-2005 | 09:09 AM
rockitman's Avatar
josh.
If that is your concern, go back to a dual mass flywheel. Seems to defeat the purpose of a single mass one if you want to slow the rising and falling of the revs....Just my opinion of course...
Old 03-17-2005 | 09:13 AM
Johnfromjersey's Avatar
Johnfromjersey is infamous around these parts
the benefits/purpose of a lightweight flywheel is to transfer power more efficiently. The faster your revs go up and down, the faster you can manipulate power output.
If you would like to sell your flywheel locally(near philly) I am interested
Old 03-17-2005 | 09:20 AM
Josh/AWE's Avatar
josh.
Josh-
It sounds as though there has been too much shaved from the flywheel. Many race cars don't idle at all since the flywheels have been shaved to save as much weight as possible.
I know exaxtly what you are talking about. It can be scary pulling up to a stop light not knowing if the car is still going to be running when you get there...
My suggestion would be either to go with a flywheel that is slightly heavier, or get your software tuner to give you some idles support.
There is a fine line with lightweight flywheels.
RallyBird
10-07-2015 01:20 PM
GSR Autosport
08-26-2015 05:20 PM
TrackOne
08-20-2015 12:56 PM
Vrseis
08-20-2015 07:41 AM
Quick Reply: is there software for using a light flywheel?
