Need your opinion on motor mounts
I need your opinion if you have stiffer motor mounts:
1) Which stiffer motor mounts do you have ?
2) Do you track events ?
3) What is/are your tolerance of comfort your willing to sacrafice for performance ?
I want to get the Rennline solid motor mounts for 2 reasons.
1) no flex
2) drops the engine lower thus lower center of gravity = better cornering speed.
Cons:
1) maybe to low already with my ride heigh and be a problem on the street
2) to much vibration that may make the knock sensor go nuts.
Any tuners know how much solid motor mounts may affect the knock sensors ?
TIA
1) no flex
Cons:
TIA
Not yet with these.
Cons:
Taka a notice that if you drop the engine from rear only, exhaust tips look quite ridiculous...there will be a 2" gap between them and the bumper.
This is more or less an urban legend...
I love my wevo's, and 997 trans mount. I got them in Oct, so no track time till April 15th here in OH.
If you never DD the car go solid trans mount and solid MM, else go with the wevo + 997 trans mount.
Tom
Tom
Wevo's
Not yet with these.
Pretty much everything... In addition to wevo's my transmission front carrier is made out of urethane and I have a LWFW. The combination is really noisy. So installing Cup shifter cables doesn't do much of a harm anymore.
IMO Wevo's flex is minimal, yet they're slightly less noisy than solids. If the trans front carrier is still OEM, it might not be unbearably uncomfortable.
Cons:
I'm running low suspension and I haven't got any issues even during the winter.
Not yet with these.
Cons:
Pete,
I appreciate your lenghtly input. I have decided base on what you said that i should just give the green light for solids mounts. I have been told that the engine knock sensors may go nuts due to the vibrations. I have driven my friends 79 SC with solid motor mouts and it feels beautiful. I want that feeling.
Thank you for your input. Have you heard of the knock sensors going haywire with solids or just a myth like Pete stated ? I do DD the car but i can live with it. I had straight pipes for 3 years. MM vibration will just be another massage for me.
I have solids...plus the tranny mount and coilovers and lowered. No knock sensor issues but with the carbon fiber shell seats.....you better make sure your fillings are screwed in tightly if you are going to drive it on the streets...
I have heard of the knock issue. I believe that it was Kevin at UMW that brought it up a few years ago. It was not from solids but from the 993 style wevos. I bet if you called or emailed him, he would be happy to discuss it.
Tom
Tom
jaehoppa
10-22-2015 09:17 PM
