A little FYI about spark plugs....
#31
I ran NGK 3330s in my first Supra and run coppers in my current white 1000hp Supra. Nothing else worked without hesitating, popping, etc... The 996TT may be a different story. Mine currently has whatever the PO had installed at the dealer 2K miles ago so I'm assuming its a OE plug.
Link: http://www.titanmotorsports.com/ngkiridiums.html
I use the 2668 NGK Iridiums in my supra; and they can be bought at any advance auto parts.
#32
I would love to hear how to change the sparkplugs without removing the rear bumper and intercoolers.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
#33
I knew there was a catch If only I had a lift in my garage. I'll bet the difficulty factor goes way up without bumper removed and no lift. Going to do my plugs in the next couple weeks.
#34
The advantage with a lift is you can see everything really well and work easily. I have never tried it without a lift, but I'll bet if you can get the car up on blocks and jack stands to gain some room under there, it's probably not that bad with a good light source. I would try this first before the other route of removing everything.
2022 Cayenne White
2022 Cayenne White
#35
Word of caution for tuned cars: call your tuner. I had a flash in the past that assumed a certain type of plug (bosch fr6), and car did not run all that great when I went with the Densos. I would use the plug that your tuner recommends as compatible with your software.
#36
I ran ngk B_EV and BR_EV (heat range in place of underscore) in most every performance vehicle I've had since the early 80s.
When I say that, I just slapped them in without regard to anything other than length and even fudged on heat range by running far too many steps colder and never had an issue with fouling.
If it fit, I put them into anything from a j-ported 1974 13-b rotary to most every crazy boosted car I've owned and they last until I sell the vehicle or build something else for it.
I'm down to my last 20 from the hundreds I got on clearance from electrodyne in 1988 and I'm not even sure they make these amazing plugs anymore.
That said, I'm running copper ngks bpr7es in my current 280zx turbo engine'd infiniti because it's power level is not intense enough for anything more.
#37
I don't have a 996tt yet (buy it friday, storing it until April), but what tools are we talking about? I've heard you need a couple of different styles of allen (long/short ball heads and super short allen). I'd hate to get the car up on a lift just to find out that I need to run back out to the store and buy tools... I hate when that happens.
#38
I do not recall exactly...there are allen head screws on the coils, then the spark plugs take a spark plug socket. But nothing special, maybe an angle socket drive, I am not sure. I have only done it once and did not pay attention to the tools...
2022 Cayenne White
2022 Cayenne White
#40
yes someone ought to make a video and sell it!! I'm about to change my plugs and not sure what route to take.
#41
can you make a video and I will be the 1st person to purchase it, being I am planning on doing my plugs in a couple of weeks!
I am serious! Lay out the tools that would be needed and go step by step I will be the 1st to call you with my credit card for $40.00!
Bobby Ali
ba
#42
:-) Bobby...I am planning on doing mine again soon. I will try to remember to list all the tools and make notes on the proceedure. I'll post it once I do it.
I do recall that with our SpeedTech exhaust there was plenty of room to do it and it went very quickly and easily for me. I have a feeling with the OEM exhaust, things are probably a lot tighter and harder to access.
2022 Cayenne White
2022 Cayenne White
#43
#44
#45
presto changeo.
http://bd8ba3c866c8cbc330ab-7b26c6f3...anceupdate.pdf
a complete step by step w/ pics.
