Broken timing chain...
Old 10-28-2011, 05:46 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
You make sure to let me know when she is done! I need to check her out in person. Looking good
  #107
Old 10-28-2011, 08:55 AM
atisvt99's Avatar
atisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant futureatisvt99 has a brilliant future
Originally Posted by ari
Talk about a phoenix rising from the ashes. That's a full on Dragon there!!
Haha, thanks! I'm pretty stoked to finally get her back and on the road - just in time for winter though.
Gunther, this thing will be firing with the help of your injectors... You can even pilot it if you want!
  #108
Old 10-29-2011, 12:52 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
What do estimate the cost will be just for the engine rebuild? Not all the aftermarket stuff. Including rods, all internals, machine and block prep work?
  #109
Old 10-31-2011, 10:36 AM
atisvt99's Avatar
Heh, I don't even want to think about it... BUT, I should have some good solid numbers here in the next week or two...
And just to clarify, you wanted the engine rebuild price WITH the rods, studs, machine work, etc? Or you want the engine build price WITHOUT all that stuff? I think I was told many many moons ago that a rebuild back to factory spec would run around 12-14k??? But I honestly don't recall... I'll have some real-world info before too long.
  #110
Old 10-31-2011, 02:43 PM
pumptech's Avatar
Yeh anything internal, rods, bearings, any crank or head work. IMO it would be counter intuitive do have engine apart and not do as much internal work as possible including cylinder head work. Why didnt you do any port work on intake of heads? Not interested in aftermarket turbos, exhaust and all the "known" items. I'd love to have an extra block to take couple years to build and have ready. Wonder what major changes between regular 996c2 or gy3 short or long block and the turbo block other than compression and such. If everything bolts together same or with minor differences just build from a 996c2 block. Guess would have to run much less boost as initial compression is much higher. Just thinking too hard probably!!
  #111
Old 10-31-2011, 03:48 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
AFAIK, there's a lot different from a 996 C2 engine, vs. the Mezger motors (996/7.1 TT, GT3, GT2).
  #112
Old 10-31-2011, 04:21 PM
pumptech's Avatar
figured there may be or the big endorse would be trying it.
  #113
Old 04-21-2012, 03:07 PM
atisvt99's Avatar
At last ...
We finally heading down the home stretch with this thing...
I'll update the story in a bit, but just came back from the shop and at 1.24 bar (18psi) and 93 octane pump gas it did the following (rear wheel)
Need a little fine-tuning from the 'Mad Scientist' and then we should be ready to go... I'll get some pulls on MS109 as well after a while.
  #114
Old 04-21-2012, 03:18 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
mid 600s...on what turbos and what fuel system, whose tuning?
-V
  #115
Old 04-21-2012, 04:02 PM
atisvt99's Avatar
K24/20GXT (billets), Proto fuel system (60# injectors, inline bosch style pump) and tuning...
But I've got a full build too... IMA Motorsport longblock (custom machine work, ported heads, rods, studs, etc...), BBI/IPD Y-pipe and plenum, Proto blow-through MAF & intercoolers, 911Tuning exhaust... I think I've covered many of the details on the last page or two of this thread. I'll revisit all the particulars though in short time...
  #116
Old 04-21-2012, 04:16 PM
c32AMG-DTM's Avatar
6300 redline? With the full build, I'm surprised you don't rev it out a little higher.
Regardless, nice results! Congrats.
  #117
Old 04-21-2012, 05:09 PM
atisvt99's Avatar
I just noticed that... I txt the shop owner and he said Tach wasn't calibrated right... He was letting off at 7k according to the dash and durmatric. So of course I asked him if the HP and TQ were not calibrated correctly either! Haha... He said we were good.
  #118
Old 04-22-2012, 10:02 AM
Tim941NYC's Avatar
hp and torque cross at 5250... Wow you did a lot.. enjoy.
  #119
Old 04-27-2012, 08:54 PM
boochook's Avatar
boochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond repute
You built a beast brother! Call me next week!
vr6tee
08-29-2015 03:52 AM
m_motorsport
08-19-2015 03:34 AM
Walorus
08-18-2015 01:39 PM
Quick Reply: Broken timing chain...
