Greddy Profec B Spec II question...
Hi gang, I have an 03 Turbo with the following mods:
-X50
-EP Stg 2 exhaust
-GIAC flash loader currently running on the 93 Pump tune
What I would like to know is if I install a Profec on my current setup can I turn the boost up to a constant 1.2-1.25bar without having to change anything else? Will the GIAC tune and or ECU compensate for the added boost?
As of right now I see 1.0-1.1 bar with seldom spikes to 1.2...
I'm running stock wastegate springs if that makes any difference. (I'm assuming changing wastegate springs to 1 bar springs would do about the same as installing the Greddy but I would rather do this instead in anticipation of other mods soon to come).
Thanks for the help!
-X50
-EP Stg 2 exhaust
No you cannot use a greddy on a standard Giac flash... you need a program that changes the ceiling maps for the boost....
Also, your stock Wg will not give it to you....
You can manually turn up the Wgs a little see if it gets you .1 bar more... but then soon you will run into LIMP mode...
markski
markski
2001 996TT 3.6L and stock ECU
markski
markski
P.S- I'll have the turbos out your way this coming week. I cant wait!
WheelB
09-14-2015 12:45 PM
PelicanParts.com
09-11-2015 02:46 PM
PelicanParts.com
BMW Vendor Classifieds
09-11-2015 02:46 PM
PelicanParts.com
Audi Vendor Classifieds
09-09-2015 03:29 PM
PelicanParts.com
Classic Porsches
09-04-2015 03:30 PM
