500Awhp?
HI,I think your answer is right....Lots of recent threads and older threads out there.Many ideas and great insight to learn what routes fit you...Just do a search.....Good Luck.......But why stay at only 500 awhp when you can go up more,once it starts it never ends......lol.....
Yes, k16/16g is good too but I would go with k24/18g because you have an 6speed.
Do yourself a favor before you make any mistakes, call Kevin at UMW (Ultimate Motor Werks). Kevin is a Porsche guru and he will help you from buying the wrong parts and making mistakes.
Good luck !
JIM in Texas
Good luck !
JIM in Texas
I TOTALLY agree with your CLUTCH comment, as if you add horsepower, you will need to upgrade your factory clutch.
I HIGHLY recommend a light weight flywheel set GT3 set up that I bought from Kevin @ UMW.
JIM in Texas
JIM in Texas
Agree, stock clutch will barely hold flash+exhaust ~(450whp). If you make a turbo upgrade to 500 whp you will need a better clutch. For your application I would recommend the billet K16s. They will easily go past 500 whp. With injectors and race gas you can get 600 whp.
Are you going to the TX Mile event at the end of the month ?
Will you be running your TT ?
Your car sounds VERY fast. Did the larger Throttle Body and larger Plenum make a big difference ?
JIM in Texas (San Antonio)
I going to make an assumption that you are asking me...LOL
Yes, I will be in Goliad at the end of the month and I will be running my TT. The plenum/TB did help significantly in two parts of the rpm band. They give a slightly faster spool (at lower rpm) and help torque. They also give more power at the very top of the rpm band and help prevent that power drop off that you see with so many turbos.
Are you bringing a car to the mile?
Mike
Mike,
Thanks for your email.
Glad to hear you will be in Goliad at the end of the month and will be running your TT.
What day and time are you running ?
I have never been to the event.
I'm not running my car this time, as I am still not finished with my car. I've been thinking of adding UMW Zero Tolerance K16 hybrid turbos. Any advice ?
JIM
JIM
Jim you live in one of the most beautiful cities I've ever seen....
You're going to enjoy the Mile..it's such a unique event!
Mike, I have to skip this time (have to work..), see you down there in October!
Mike,
JIM
JIM
I will probably run Fri or Sat depending on conditions. I always run as early in the day as possible.
I dont know alot about UMW turbos so I cant comment on them one way or another. As you know turbo choice is heavily dependant on how you plan to use the car and what your priorities, goals, and cost expectations are... Ie is the car primarily a street car, track car, straight line pulls, dd, garage queen ect...
