PCM1 - Help with radio
My PCM1 system has a fault
Everything works except the radio itself
It doesn't show ther stations, and there's no sound
The fuse in the fuseboard is ok
Is there a fuse at the back of the PCM unit which could have blown, or is it something else?
Their is a fuse on the back of the unit. Also check the coax that connects to the rear of it as well. The radio comes out bt popping off the left and right switch trim surrounds. Once those are off you will feel the four radio releases. Two on the left and two on the right.
Sorted! - Thanks!
For anybody that happens to stumble upon this thread in the future........
If there appears to be no power to the stereo - the fuse in the footwell has blown
If the display works, but there's no sound or radio presets - the fuse at the back of the headunit has blown
vpr80
03-06-2021 12:11 PM
alpha motoring
10-02-2015 12:04 PM
Mz3bo
10-01-2015 06:32 PM
