Refinishing Alloys - What Colour?
Very well spotted!
I actually like small wheels
Small wheels, low offsets, and negative camber = good times
I like brushed centres, but I think they look better on flat faced wheels like yours
Do you think brushed centres on a round faced wheel would look good?
And if I did go for a brushed centre, what would I do with the centre caps?
I hear what your saying about the brushed centers and you have a point, I personally was thinking about doing the centers of the next set of wheels in a flat light grey and then high shine polished lips for some major contrast. Could be an option for you also, i think it would give an illusion of the wheel face really being tucked into the car and the lips to be magnified at the edge of the fender
They were clear coated when new
Because the rim is polished there isn't much 'mechanical adhesion' for the clear coat to stick to the rim, and so it peels off
The clearcoat also tends to crack around the perimeter bolts
Water gets under the clearcoat and causes it to lift
A possible way around this might be to go for a brushed finish rather than polished so the clear coat has something to 'grab' onto, and to clear coat them after the perimeter bolts are fitted and not before
What do you think?
What do you think?
I do too, I am looking to get myself a set of fikse fm5's (5 star stepped lip) which is a similar design in 18". If you give the car a nice drop and tough stance they work well if you have low offsets.
I know what you mean about stance - I still remember the pictures you posted of your car
Two of the ones that really stick in my mind are a side profile - car facing towards the left......and a close up shot of the rear, showing the offset on the drivers side
Those pictures and your car look brilliant
ECS Tuning - VW
09-28-2015 03:19 PM
