GT2 or HR rear sway
Old 04-05-2011 | 09:34 AM
snopdog911's Avatar
snopdog911 is infamous around these parts
GT2 or HR rear sway
which is the better option for 996tt?
HR is $240 and GT2 is $310
GT2 is lighter
any other difference?
i read that there is no need to change out the front
Old 04-05-2011 | 03:24 PM
SikPorscha's Avatar
SikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to behold
I'm thinking of getting the Gt3 rear sway.
Old 04-05-2011 | 05:25 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
I just had front and rear H&R sways installed, only got to drive the car hard briefly and notice right away the front end feels like its not pushing/ sliding out like it did previously, stays more planted and goes where you point.... not sure why you feel you don't need the front?
Old 04-05-2011 | 05:59 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Conventional wisdom is to stiffen the rears to reduce understeer, nominally increase oversteer and increase handling sensitivity with throttle application. Contrarily, especially with an awd platform, racing wisdom is to stiffen the fronts (relative to the rears) which improves turn in and tracking. That's what you're really after. Simply put, you need the front sways, keep an open mind on your initial set up and see what works best for you in the conditions you drive in. Best,
Opposing perspectives are always welcome....
Old 04-05-2011 | 07:17 PM
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
go with gt2 as its hollow
04-28-2022 12:38 AM
r_matt_6
10-08-2015 06:07 PM
orbelo
08-30-2015 12:26 PM
TrackOne
08-20-2015 12:56 PM
Quick Reply: GT2 or HR rear sway
