2001 Turbo Flashing Yellow Light high RPM's?
It is almost def. the traction control light. Click the button that says PSM and make sure it is off.
Thanks everyone. PPI came back good and I ended up purchasing! Car has been flawless so far.
One minor thing I noticed, which seems weird and couldn't find anything about it - When the ignition is off if I get out of the car and close the door the speedometer light, mileage and clock don't turn off unless I lock the door. I sat outside the car for like 10 minutes to see if they would turn off without me locking the door and they didnt. I have to lock the doors for them to turn off, is this normal? Is there a setting I can switch to change this?
Thanks Again! The car is awesome!
Thanks int90. I guess I will let it go for a little while and see if it turns off.
Lennon, I think it was probably the PSM. PPI came back and they said if the check engine light was flashing it would have been recorded. I havent seen the light since.
Thanks Everyone!
Thanks Everyone!
09-01-2015 03:16 PM
oddjob142
08-19-2015 12:27 PM
