Highest HP Modified K24 Based Engine
Thought I would save Luis stock K24 thread !!!
What is the highest substantiated HP on modified K24's ? What turbo spec and what supporting mods were used to achieve ?
Quite a few have trodden the step by step upgrades using K24's over the years and the numbers we are now seeing are higher than ever.
To be clear -- I referring to anything but stock turbos. There has been quite a series of developments of available upgrades for K24's over the years and I am interested to see updated results for them.
Here is my car on pump GIAC file. No doubt it would make more on the race file in the race fuel setting since that is essentially more timing (not more boost since the at 1.2 bar the turbos are already at max output). Third party dyno, so no shenanigans My guess is 2-30 more HP on race fuel with race setting
I can't recommend the wastegate upgrade enough! Really woke up the throttle response, mid range and consistent power delivery!
No longer running K24s, but these were good numbers on exhaust, wastegates and flash! That said Dynojets really overstate. I'm a big fan of a properly set-up and calibrated Mustang dyno like GIAC's and EPL's. Like Tony @ EPL said once, how can you trust some of these dyno results when a stock 996T makes 420 AWHP? Cough Cough
OOPS after reading this again I think the OP was asking for power results with modified K24s. These results were with factory stock parts...
6speeder TTBoost was making 600whp with 18g's, injectors and meth, everything else stock. His car now has inlets, IC's and Ypipe and is being retuned.
Bmoores has a 20g car and he did a 5.73 60-130 a couple days ago.
I know there are some K24/garret and billet k24 hybrids out there but I don't know power figures or 60-130 times.
you could make 680whp with 20g' turbos on the very limit of the bottom end with
Ford MAF
intercoolers
3" intercooler piping and y pipe kit
large throttle body
3" exhaust no cats minimal mufflers
big injectors and pusher fuelpumps
adjsutable FPR
your going to need to run 1.8bar have removed your front drivetrain and run race gas or E85 to achieve it though.
Ford MAF
intercoolers
large throttle body
adjsutable FPR
Ford MAF
intercoolers
large throttle body
adjsutable FPR
Ford MAF
intercoolers
large throttle body
adjsutable FPR
I think Chris Green made 717whp on 24/18g's and E85. Thats the highest number I've ever heard on a K24 based turbo. There is the white 24/20g car up in MN that used to belong to Bobby. That was running 1.8 bar on C23. That car trapped 143mph if my memory serves me correctly and ran a 9.99 from what Todd Knighton told me. I would guess that car was making roughly 750whp.
I'm going to strap my car to the dyno one of these days but at 1.6bar on the 20g's my guess is that the car makes damn close to that number. I need to adjust my wastegates but i'm confident this car will go 5.5 or better 60-130 with 1 shift. If we are going to (bench race for the sake of discussion ) compare those numbers with cars that have made similar power on the 60-130 charts the the car below me made 755 and the car above me made 724. I don't think my car is making 755 or anywhere near it but it should be in the 680 range.
sometimes more power doesn't always mean a faster time
Absolutely, the intangibles will always play a roll. It's just nailing down exactly how big that roll is.
As for the dyno number ..... I don't care what it is as long as the car keeps performing as it has for the last 18+ months.
OK,,,You K24/20g guys.....Question,Your opinion,,,Do you think at 1.3 bars on pump gas only and the supporting mods I have in my signature.......which is what most K24/18g members have.....Do you think at this level it would be a good up grade worth it to go to K24/20s and a new map???Just like to hear your thoughts from Members that have been there done that......Thank You.......Also,sorry to ask this on this thread,,,but they still are K24s.....lol........
and the new turbos Tony uses are Billet versions 18gxt 20gxt so there is a updated wheel design for guys looking to make changes. (same cost as before)
the 20g will choke without a Blow Through MAF, and last i heard Tony does not like to use Blow through MAF's so would be something to discuss with Tony.
