Evolution Motorsports Breaks 60-130 Record
#35
OK, now that all the high fivin is over. I have to thank Todd, John and the entire crew. Especially TopGun for convincing me e85 was the future( I will never hear the end of this) . This car ran a low 5 sec run in the past, but I had numerous problems at the time including a clutch and flywheel that were shot, but making excuses isnt my thing. I knew the car was faster but it just had to be proven. I took my time and let it stand without the typical BS whining about why it didnt go faster. Fast forward to the Fall of 2010 when we decided e85 was a viable solution to my needs. I wanted a daily driver that ran at its rated power all day, everyday without the need for leaded fuels and separate ecu files. EVOMS took off the straight pipes and made a full exhaust, changed to a blow thru intake and added larger injectors. Nothing else change. It previously did around 830tq and 930hp on c16 at 8000rpm and 29 psi. With the new fuel we dropped boost to 26 and lowered rpm down to 7400 and in this configuration it made 902AWHP/908AWTQ. The car has run a 29 psi and I will give that a try but the RPM is remaining where it is. Thanks EVOMS!
#38
#40
Congrats on the new record KPG and EVOMS!
Although Im sad to see my record knocked off in a mere 30 days , I truly am excited to see that the Porsche cars are really starting to perform at the top of the fast car food chain.
KPG & EVOMS, Scott posted that you guys did this pull starting in 4th gear with 0 shifts. With that said, its obvious you guys changed the gearing in the car to accomplish this. What RPM is your car running in 4th at 60 mph?
Again killer time...you guys have to get back out there with some more boost or atleast with some colder temps to see if you can squeeze some more out of it.
Keith
Keith
#41
Again killer time...with a zero shift car, you guys have to get back out there with some more boost or atleast with some colder temps to see what that thing can really do.
Keith
Keith
Stock Gear Box..
#42
Keith
Keith
#43
Very nice! Even more impressive.
#45
I'm fully aware. Ive been running E85 for about 8 months or so now in my 997tt. Was on E85 when I ran my 4.14 60-130.
E85 is great. Cruising around town always on full kill mode!
