codes definition
P0491
Secondary Air Injection System, Bank 1 – Below Limit
Diagnosis conditions
• Intake air temperature 4.5 - 60 °C
• Engine temperature 4.5 - 102 °C
• Mass air flow 36 - 150 kg/h
• Engine starting temperature less than 42 °C
• Altitude correction factor greater than 0.75
• Oxygen sensors 1 and 2 ahead of TWC are ready for operation
• The secondary air injection pump is switched on
• Diagnosis has not yet taken place during this cycle
Possible fault cause
♦ Secondary air injection pump is not triggered
♦ Secondary air injection pump does not work
♦ Air supply lines restricted
♦ Electric change-over valve does not function
♦ Air change-over valve does not function
♦ Vacuum system leaking
Affected terminals
III/11 and III/14
Affected terminals
III/11 and III/14
P0492
Secondary Air Injection System, Bank 2 – Below Limit
Affected terminals
III/11 and III/14
Affected terminals
III/11 and III/14
Bmw M3 Guy
02-21-2018 09:29 AM
