Kit for adding extra fuel pump???
#31
Tom
#32
Hey Tom,
Any chance you can snap a closer pic of where your pump sits now? John D. posted up a big pic, but the pump isn't real visible... Thanks!
John D, if you have a 2nd pic laying around - that too would be great!
#33
Hey Tom,
There you go, don't be jealous of my amazing paintshop skills.
#35
HEY Guys,This is really turning into a great thread with info and help.....THANKS.....You would think with this as being a real restriction for some worth while gains with bigger turbos and injectors,as most have,,,,that there isnt a kit out OR tuners do not inform you of the possibilites of what their Street/pump gas maps can do once this issue is addressed which would help their bragging rights for sales plus make them extra money with kits OR a single Bigger pump kit that works and easy install.At this level that we are into it,to need it ,whats a few more bucks...lol...From what I have been told so far, that a 044 pump really isnt go to do anything over replacing the factory one with it??.......
#36
You're talking about *only* replacing the factory pump with an 044? If that's what you're asking, I've heard that it isn't a plug-n-play swap anyways. But that the 044 is more of an in-line pump and still needs something out front 'pushing' to feed it...
I started a fuel pump thread a little while back - as usual, it started out good and strong, and then died off before anymore data could be extracted from our user base.
And I wish that dgreen78 would chime in here... He has two 044 pumps (custom) mounted in his tank with bigger braided lines headed to the rails.
Some companies will sell you upgraded lines to work with the stock pump, some will sell you an in-line to work in conjunction with the stock pump while keeping your stock lines... some users (Tim in NY) will swear by a single big pump, others will turn their trunk into a sacrificial fuel delivery pod and fill it with all kinds of equipment!
SO. MANY. OPTIONS...
#37
#38
HI,Thanks for your info.I was looking to get more fuel,as Tony from EPL said I needed now.I was told just about duals,thus this thread.But others mentioned an upgrade to a 044 single will do it which I do not think it will do it. Tim has been very helpful and informative,good guy....So,if I may ask,Please tell me some of these companies that sell these extra in line pump things that you mentioned....Thank You......
#40
You are talking about something totally different,,,As Tim explained,,,,But thanks for your input
#41
This is a very safe system and I fill up the methanol container every 3-4 gas fill-ups.
#43
I don't need luck Tim. Tony at EPL recommended and tuned it. The car is extremely safe and I have a ton of dyno runs and Durometric logs to make that statement. I know this isn't exactly what the threadstarter asked for, but it is a viable and safe alternative the achieve the same goal. All I am saying is it warrants a call to Tony at EPL, the guy that is already tuning his car.
#44
#45
Hi,,,Tony was in contact with the dyno shop,Kelly Moss,when my car was on their dyno....Tony said I was running out of fuel and that I need another pump.....Nothing about meth. injection was said,,Plus in my opinion that is not a true fix but a band aid IF their is a problem with lack of fuel......Sharing is all good....
Please keep us all informed.
