Shake your money tree! New EVO Venturi-style Air Intake
any issues with mass air sensor/ CEL etc? (similar to the NA 996 conical filters) How often does the conical filter need to be changed? Is the growl with acceleration pretty noticeable in a relatively stock TT? Overall seems pretty awesome! I haven't seen these type of air intake for a TT before, why now are these available I wonder??
The filter is like any other filter, you'd clean/change it every 40k or so. Seeing as I can here it in mine with a super-loud exhaust I would say "yes" in answer to your question.
I installed an Evo intake on my car - definitely makes a fun sound, as you can hear the BPV's blowing back into the intake piping (not like a BOV, much much more subdued). Makes the turbos whoosh more, if you will.
Not sure how it sounds on the Turbo, but 30hp is nothing to sneeze at (if it is indeed that high).
Originally posted by KJM3
If my ECU is already flashed, do I have to get my car flashed again after installing the intake? Or is just a straight bolt-on part?
Thanks,
KJ
Thanks,
KJ
It took so long before anything came out because of the reason I mentioned above and the inability of actually getting cold air in as opposed to hot air.
I'm as bit confused. Are you saying that if I put this gadget on a stock Type 996 (GT2, Turbo, Turbo S), i.e., without any other modifications whatsoever, it will increase power by 30 HP? And, if that's so, is it 30 HP on an engine dyno or at the wheels?
