clutch options for K24/18g?
Old 05-04-2011 | 04:47 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Originally Posted by PAULIEWALNUTS
My CM 3 feels just like a stock GT2 clutch. I stayed with the dualmass flywheel & I think that is what made the difference.
You are also old and have little to no feeling in your legs.
If you think you may end up going for more power down the road. Go for the best and get the Tilton.
Old 05-04-2011 | 05:07 PM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Ben will let you use his credit card. Ben has little to no feeling in his head,unless you drive a TT lambo,then he is your best buddy.
Old 05-04-2011 | 05:13 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Zing!!
you are also old and have little to no feeling in your legs.
If you think you may end up going for more power down the road. Go for the best and get the tilton.
Old 05-04-2011 | 06:28 PM
bmoores's Avatar
How are those 5 gallon pails of 87 octane working out Paulie??
Old 05-04-2011 | 07:48 PM
Hi my name is BenName:  nut swinger.gif
Old 05-04-2011 | 09:40 PM
heavychevy's Avatar
Originally Posted by vividracing
If you order one from me, it does, they make changes for us. I have it in my car. Thanks.
Didnt know that, might be a good idea to clarify a certain layout, because that is far from the norm. Though the CM3 is a great clutch.
Old 05-04-2011 | 10:10 PM
johnspeed's Avatar
HI,Do yourself a favor and do a Search,,,,Many opinions and truths,,,Good Luck......
Old 05-05-2011 | 09:10 AM
I have had great luck with the Clutchmaster stg 3(fiber tough). You might want to talk with Tony from EPL and see what he recommends.
this is what i use.
#TeamAIM
Old 05-05-2011 | 09:39 AM
johnspeed's Avatar
Hey,For what its worth.........I put a CM stage 2 which is the same as a Vivids CM stage 3,as I was told by CM.. . I did not like it...Instant grab,hardly any modulation and solid engagement,no cush,,,,I know others swear by this set-up......I took it out after 500 miles or so and put a CM stage 1 in....Alot better to live with..If you do a search on clutches,I did a full review on this about a yr. ago....The stage1 does holds my K24/18g power...Its in the pressure plate mod which is the same for both....Just my input.....Good Luck
Old 05-05-2011 | 11:27 AM
SaMaS's Avatar
SaMaS is just really niceSaMaS is just really niceSaMaS is just really niceSaMaS is just really niceSaMaS is just really nice
anyone running Sachs/AWE St2.5 Clutch ?
Old 09-20-2011 | 08:05 PM
tomjack's Avatar
tomjack is infamous around these partstomjack is infamous around these parts
Follow up- it's been a few months. I went with the clutch masters stage 3 and I love it. VERY close to stock feel. A little early on the engagement, but otherwise this is a great clutch for a daily driver like mine.
Old 09-20-2011 | 08:08 PM
tomjack's Avatar
Originally Posted by heavychevy
Clutchmasters stage 3 Drives like OEM? Yeah right.
It actually does! No joke. My 110 lb girlfriend even drives it with no problems at all.
Old 09-21-2011 | 04:31 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I'm running the upgraded Sachs
clutch with k24/18g's with no problems. Keep in mind I'm running a 91 octane tune, so I'm in the 500WHP range. My installer (Vision Motorsports) has installed this setup on many cars, and was confident it would hold up to 700HP (crank). I could probably dig up the receipt and post part numbers if needed.
I don't run the 1/4, so no hard launches. So I can't say how well it would help up to abuse, maybe others can comment on that.
Similar feel to stock.
Originally Posted by tomjack
I'm sending out my turbos for the K24/18g upgrade, along with a 5 bar FPR, wastegates, and EPL tune.
What is the most cost-effective clutch replacement option I should be looking at?
This will be for a daily driver with no track use or hard launches.
COBB Tuning
01-29-2022 10:42 AM
ECS Tuning - VW
08-27-2015 03:44 PM
