Gauges not working
Gauges not working
I just had the gauge faces replaced (from silver to black) and now the tach, batter, and oil pressure gauges are not working. I have checked that theconnectors are securely in place. Any ideas?
Possibility: related fuse are E1 B1 B10 but take a good look at the connector because there is no relation between tack, oil pressure power wise ????
I am not sure if its gonna work on yours .Last time this happen to me I pulled the battery cable left it for a minute reconnect the battery and everything was fine.
Check to make sure that the needles were not pushed down too far. If you put them on too tight, they will make contact with the gauge face and not be able to turn. If your problem is not electrical - this is it.
Edit: Check my writeup at: https://www.6speedonline.com/forums/...ml#post3164827
I finally got it open. The needles of battery gauge and tach are free moving inlike the ones that are working.
nlakind
11-06-2015 10:15 AM
RallyBird
10-07-2015 01:20 PM
turbotuner20v
09-11-2015 12:02 PM
ECS Tuning - VW
08-28-2015 11:48 AM
