Brake caliper puck holders
For you guys with brake systems that have the ceramic pucks that are between the caliper piston and pad backing plate, here is a solution for holding the pucks in place once the rubber seals start to deteriorate. Trackers will get the most use from these because of the extreme heat generated at track speeds that breaks down the seals.These are available from orbitracing.com for about $135 for a set of 20, complete front and rear.
Check out this DIY :
http://gt2gt3cup.org/showthread.php?t=53
I am unable to transfer the pictures here. There must be something in 6speed's system that won't allow it because I uploaded to another forum without problem. Try this link and see if it works.
http://www.renntrack.com/forums/show...c-puck-holders
ECS Tuning - VW
09-02-2015 09:03 AM
