Engine coolant, what should I do?
Old 05-19-2011 | 07:25 PM
jayster's Avatar
jayster is infamous around these parts
Get the factory coolant, 23.00 a gallon mix it 50/50, its good to -35 or so. You'll need 2 bottles, you'll have a little left over, for emergencies.
Some times the factory stuff looks "orangy" too so dont worry, If you are worried, rinse it out with a hose and fill er up with your premix. Gently heat cycle the car 2 or 3 times, topping up in between, and your good.
Old 05-19-2011 | 08:03 PM
pwdrhound's Avatar
Coolant capacity is shy of 8 gallons so if you drain it really well you will need more than 2 bottles or 4 gallons of mix.
Old 05-20-2011 | 06:11 PM
jayster's Avatar
I wouldnt try to DIY a total drain and fill, have a shop do it, should have qualified my statement. Even a water pump replacement doesnt drain over 3 to 4 gallons, unless you are really slow....
Old 09-28-2011 | 08:10 AM
Parkcity911's Avatar
Parkcity911 is infamous around these parts
Thanks for the info. I'm in the same boat too. Does anyone here use Redline water wetter or Royal Purple "ice" to boost coolant effectiveness? Thanks.
mikerosi
12-06-2018 07:23 PM
viprklr
05-23-2018 12:33 PM
nlakind
11-06-2015 11:15 AM
sypherdiaz
08-29-2015 01:16 PM
LiquidElephant
08-27-2015 07:17 PM
Quick Reply: Engine coolant, what should I do?
