996 Spacers, Lug Bolts - Everything you wanted to know
Thanks Ari
I agree it's best not to use spacers and to buy the correct fitment to begin with
What I'm planning is to try various spacers with my current wheels and once i'm happy with the look I'll buy my new wheels with that offset
I know you've tried a few spacers in the past, can you tell me;
Am i right in saying a 7mm spacer doesn't have a 'lip/nose' on it at all?
From what you're saying, If I trial with 7mm spacers I'd need 12-13mm longer bolts (or as near as is available) correct?
Thanks again mate
Thanks again mate
[QUOTE=ant_8u;3410749
[/QUOTE]
The RUF 7mm spacer I use is the only spacer I know of that has a hub centric lip on it. Even though you have a small amount of the hub sticking through the 7mm spacer its nice to have the larger lip.
[/QUOTE]
H&R and RSS are hub centric for all spacers 7mm and larger.
My bad I guess. I could have sworn that RSS's 7mm spacer was hub centric. I'm getting old. I have their 15mm on OEM and they are of course. They are really well made. I probably would not want to use a spacer that wasn't hub centric.
I apologize if this is a redundant question, but if I have 19x8.5 fronts with 45 offset and 19x11 rears with 40 offset, should I get the 7mm or 15mm spacers? Also, I currently have 235 35 and 305 30 rear tires respectively.
thanks in advance
thanks in advance
BlackMarketRacing
12-03-2015 10:46 AM
