Oil Change Questions for TT
Old 04-08-2005, 09:41 AM
ImagineAuto's Avatar
ImagineAuto is infamous around these parts
All,
A few thoughts on oil changes in TT's:
-Be careful about adding the dipstick as the filler neck has changed since the early cars. Porsche advises against adding it as you could damage a sensor.
-We always drain the turbo's; why not remove as much old oil as you possibly can? Same with changing the filter; why not?
-When adding oil back in, we typically add about 6 qts and start taking readings from there. Adding 8.5 qts initially may lead to overfilling and having an oily MAF.
-Yes, the car should be level to ensure proper draining.
Hope this helps,
Team IA
Old 04-08-2005, 10:34 AM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Thanks for the information.
Don't you have to warm up the engine/new oil before taking readings?
Old 04-08-2005, 10:47 AM
Dock,
Yes, the system will not provide a reading before operating temp is reached. Typically, after starting with 6 qts, we add 1-2 more based on the "gauge".
Thanks,
Team IA
COBB Tuning
01-29-2022 09:42 AM
BLKonBLK911C4S
NorCal
08-29-2015 03:20 AM
gulf gt
08-27-2015 10:27 AM
00aston
08-27-2015 12:01 AM
Quick Reply: Oil Change Questions for TT
