can I lower 1" with 20 inch wheels
That's pretty much the question. I'm worried to do all the work for the end result to be putting the stock stuff back on and something to put on eBay. Lol
Anyone done this?
Anyone done this?
Whats the width of the 20" wheels, offset, and tire size. These will have more influence than just up sizing to 20" wheels with the same dimensions as stock. Putting larger width wheels on doesn't yield as much handling gains as a properly set up suspension. If I had a choice, I'd stick closer to a stock spec and keep the money in suspension upgrades.
Are you sold on 20's? Each increase in wheel diameter also decreases your performance and increases your cost for tire replacement. 18's are the best overall solution. They perform better than 19's or 20's, and the tire choices are much better and less expensive.
Dubs are normally not purchased for vehicles destined for the track, in my experience. Usually for cars that are going to shows, or a Fast and Furious screening. (Just a joke) Different strokes for different folks, I guess.
Seth. I don't track my car. I'm not a "race car driver". Different strokes for different folks huh.
Don't try to tactfully "rag" on me.
Just asking a question. Not for pithy comments.
Back to my question. Has anyone done this and got away with it
What you may run into is an issue with square shoulder tires. You may end up having to go just slightly small on the tire and stretch it to get some radius on the tire. I'd test them at the tire shop before leaving with them mounted up and non-returnable.
The other solution is to purchase your tires through someone like Wheel Enhancement that has a lot of experience with this and see what they say.
Are you just dropping the car with lowering springs or are you going to have some ride height adjustment? In cases like this, it can come to millimeters making a difference between epic win and epic failure.
Jim
Jim
A good suspension shop can do this pretty easy. A super stretched skinny tire, and a pack of 3,5,7,10,15 mm spacers to bump it out perfect. There are a number of forums dedicated to this like stanceworks.com that can help with a bit of tuck and poke, if that is your cup of tea.
Tom
Tom
The wheels simply "start" closer to the body when you lower. The point is that if you go over a speed-bump, the suspension will have less travel in a lowered car and will simply stop where the stock suspension would have stopped. Your wheels will not get any closer to the body than they would with the stock suspension with the suspension compressed.
04-28-2022 12:38 AM
