Question about lower control arm ball joint
Old 06-01-2011 | 07:28 PM
pane2k's Avatar
pane2k is infamous around these parts
Where the lower control arm goes in to the knuckle there is this shim plate that has grooves around the edges. Does anyone know if this piece is sold separately? If so, does anyone know a part number for it? I have the diagrams from porsche and it's not documented in the pictures. I don't know, maybe it comes pressed into the knuckle from the factory?
Thanks in advance for any help.
Old 06-02-2011 | 08:08 PM
jayster's Avatar
jayster is infamous around these parts
sounds like the insert for the control arm pin. You should not be seeing so much of it! Did it come out with the arm?
Old 06-02-2011 | 08:23 PM
Tim941NYC's Avatar
They do come out with the ball joint sometimes. You can reinstall them. I might be able to locate one.
Old 06-02-2011 | 08:44 PM
jayster's Avatar
Ive only seen them come out when someone separates the joint with a hammer, not good IMO.
04-28-2022 12:38 AM
COBB Tuning
11-09-2015 08:02 PM
orbelo
08-30-2015 12:26 PM
The Oss
08-24-2015 08:19 PM
TrackOne
08-20-2015 12:56 PM
Quick Reply: Question about lower control arm ball joint
