Engine Oil Overfill
Engine Oil Overfill
So I took my 996 turbo to a shop today for an oil change.
They drained the oil (well they thought so), and then replaced filter, and added 8.7 liters of oil.
Then I start car, check oil level on dash, and it reads 1 tick higher than max. I tell them "Its got too much oil".
Then we take a look at the airbox and it has oil coming into it! Thats right, oil coming from engine, up the cold air tube and back into the airbox. Air filter is fubarred now, probably MAF too.
I found out that they only drained the oil from the crankcase, not from the oil tank.
SOOO they completely overfilled my car... BIG TIME...
They were nice enough to drive me home and my car is there for the night while we wait for new air filter from Porsche.
But. What should I do now to ensure there is not more damage done?
I could take off the tubes that go to the turbos and clean them.
Should I remove intercoolers and clean them out too??? I think its pretty normal for intercoolers to be full of oil though maybe I would be wasting my time.
surprisingly the car started fine and only blew a bit of smoke.
HELLLLLLLLLLP!!!!!!!!!!!!!!!!
Where did you take it for an oil change ?
Yikes, I would get the oil level right, clean up as much of the oil as possible, clean the MAF with electronic parts cleaner (I picked up a spray can at Home Depot) then have it checked out by a qualified tech on their dime.
I had the same thing happen to me when I took my car to a friend that owned a oil change shop. They didnt realized there were more than one drain plug. It was over filled by at least 6 quarts. It smoked like a smoke machine for 2 days. I had to replace all of the O2 sensors, MAF, oil filter etc. In the end it cost about $4200 to get it straightened out. Big lesson learned. From now on I only take it to dealership.
Did you have to pay for all that or did the shop pay?
Well since it was a friend and he was doing me a favor, I covered the cost. Although I do get free oil changes on all of my vehicles now. At some point it will even out. LOL
I looked at a car last year that has a brand new ($32K) motor as it was taken to Tire Kingdom for an oil change and was overfilled like yours. I hope that doesnt become your fate.
The guy's sales line on why I should buy his with a factory/dealer warranty was, admittedly, "since I am selling it I tried to take the cheap way out, but at least you'll benefit as it has a new motor and a 2 year warranty." I passed on it.
Diy
If you end up needing to replace this stuff, do it yourself, these things are pretty easy to change. Get the Bosch branded O2 sensors for under $100 each.
Any concern with the plugs getting fouled ?
Wow, total amature mistake by the mechanic! He obviously wasn't a Porsche certified mechanic. Hopefully this shop owns up to their mistake without a fight because this could be expensive. There is plenty more than just the air filter that is now oil fouled. Hopefully this didn't cause any big damage but sounds like you were smart enough to check the oil right away and didn't run the car very long.
