Q for those with K16 billets
I hear ya. It's not a light car so if you really want to be safe, best to run the highest octane that's affordable if you're going to push it. I'm sure your friends at VP know what they are talking about. It all depends on the fuel too. For instance, pump fuel which uses ethanol as an octane booster is fairly volatile. So I would be concerned about leaving pump fuel stagnant for any length of time since ethanol will evaporate. If you use C16, a leaded fuel, then it's the lead that serves as the anti-knock agent so evaporation is less of an issue because lead is not going to evaporate. In any event, I agree that leaving fuel stagnant is not the best thing.
Ok campers. I made up my mind.
I talked to Dan at Vivid and am buying the K16/16G turbos and 60 lb injectors along with an updated tune package.
I upgraded the brakes awhile ago.
Looks like I've got some shopping to do for GT2 clutch packages in the near future. Expect more inane questions.
Last night I added billet diverter valves from Speedtech.
I need to take a break while I wait for all this goodness to get here. I think I hear the wife's Mercedes calling me....
Jim
Jim
Jim
GT2 clutch will probably be ordered next. I'm methodical.
I need to look at any options. Although I tend to take the factory option that meets the need. I was going to go with X50 turbo components but couldn't get the deal to fall the way I wanted it. Bummer.
See "thread on all the other stuff I bought to support the turbo upgrade.
Jim
Jim
I don't think the K16/16G are the same turbo as the K16 Billets. Your title says Billet where this last post is K16/16G. I thought the Billets are the 'new' tech that spool really quickly and produce crazy TQ, while the 16Gs are older tech, but larger wheel so they flow more than stock.
Right?
Right?
Right?
Right?
Jim
A gt2 clutch wont hold the extra power for that long, you should do the GT2 SLAVE delete along with a stronger clutch for the extra power
Jim
Jim
Right?
Right?
or AMS!
Jim
Jim
Jim
