CEL, P420 or P240
CEL, P420 or P240
I got a CEL and must have cleared it by accident. Sure didn't mean to. It was either P420 or P240. Something emmisions related, low value I think. Can anyone help?
yea, your cat is most likely going out or it could be your 02 sensor. If you let it sit to long your 02 will go out. I throw this code in one of my cars weekly and just keep resetting it
What's up with P0800 ? Did you find anything out on that and which Porsche code does the generic, my guess P0800 relate too?
You'd have to take it apart, I've never taken a cat apart so i don't know. Hence why I've been resetting them for the past few months, but now i'm up to resetting it every 2-3 days
Too cheap to go get it fixed though.
Does your exhaust make a little rattle wheezing noise on occasion at low RPM's. It could be described as a pebble floating around sound in your exhaust
IF YOU CAN GET THE O2 SENSORS SWAPPED FROM SIDE TO SIDE IT WOULD HELP IN DIAGNOSING THE PROBLEM.IF THE FAULT FOLLOWS THE SENSOR IT IS A BAD SENSOR,IF NOT IT COULD BE A BAD CAT OR A WIRING PROBLEM.
