Handling feels loose over bumps
Recently I started noticing my car feeling a bit loose sometimes as I go over bumps. It's most evident when I change lanes and go over the markers in the road where, occasionally, the car feels like it wants to slide the front end in one direction. The effect is pretty subtle, and it doesn't seem to affect cornering but I'm wondering what the issue is.
I've checked the droplinks (swaylinks) and they appear to be fine and snug and I did a cursory glance at the rest of the internals (wheels on, so it wasn't that thorough) and they seemed ok.
I'll probably try checking for play in the wheels (to check the tie rods) over the weekend. And if none of that works, maybe try getting an alignment. The suspension is bone stock. Any other ideas of what it might be or what I should check?
VAGscum, You're totally not insulting my knowledge or experience. As far as both go, i have very little! I've just recently gotten into fixing and messing with cars so I'm a noob just figuring things out as i go along. Thanks so much for the pointers.
You're indeed right that I didn't properly check the drop links. Would bad droplinks just be overly loose and not taut? I imagine they'd be strained and basically get elongated.
Thanks for the advice on checking the control arms and tie rods. I'm doubtful it's a tie rod or bushing (the car only has 25k miles, though it's 10 years old, that still seams a bit young for those to go), but better safe than sorry. Incidentally, I just ordered an x73 suspension kit, so if it isn't one of those, i may forgo the alignment til after I install the new kit.
Again, major thanks for the pointers man!
No worries.The bushings will become elongated and have been know to cause a clunk sometimes. What end of the car feels loose? Front or back?But the loading of the sway on the compressed suspension on the ground will often times load the drop link against the force of the extended suspension that is in the air. This makes the movement of the link almost impossible to diagnose.
Thanks again!
LiquidElephant
08-27-2015 06:17 PM
