Unable to pass emissions, cant register car!
My car is gutted of all that BS. I was still getting the secondary code. I fix that by plugging the line that has the solenoid valve on it, I stuck a ball bearing in the line and put it right back on. It is the line right next to the vacuum line for the brake booster. I think it is for evap system but don't really care enough to trace it down. Good luck, hope this helps.
Good luck with that......
You may be able to, in some states you have to show that you spent some required amount of money to attempt to fix the problem (usually a few hundred dollars) and you get a waiver for a year. I had an 87 Carrera that almost required it, but ended up finding the problem. Good luck.
PorscheEnthusiast
11-13-2015 02:23 PM
Walorus
08-18-2015 01:39 PM
