So, Has Anybodys Car Ever Just Cut Out On Them?
....Cuz thet's what happened to me today
I was driving along the road, and the car just cut out
No warning, no splutter, nothing
I put my foot on the clutch and all the dashlights illuminated (although this could have been a coincidence as far as timing goes)
I got my car towed home, I haven't tried to start it or anything else yet
I'm guessing the first thing to do is buy a code reader and see if anything pops up
Where's the best place to get a code reader - I know nothing about them, are there different sorts, etc....
In the meantime whilst I wait for my code reader to be purchased
Who fancies a little guessing game?
Rep points are on offer for the closest guess
The durametric is the best. I'm not very mechanically inclined, but if everything cut out but your dash lights were still ok, i'm guessing it's fuel system related and not electrical system related
And there's some rep points at stake!
Nope, normal dry day, just plodding along on the motorway
The fuel computer showed ~150miles remaining
Yep, my fuel pump died a week after i bought the car and exhibited the same symptom you describe. The (overly complex) fuel pump has a main body and two separate scavenging arms which operate via a venturi system. Lose a seal on either arm and it's all over because the suction is gone. New pump ~$950. Good luck. Do a search here for fuel pump and see one convoluted device.
I had some stalling issues recently, turned out to be a dirty throttle body, possibly due to the bmc filter. A dirty MAF can also present in this fashion. Could you restart the car? Any CEL?
In my case it wasn't the pump.. and usually its not... its the fuel pick up assembly.... disconnect the battery... if the car turns and doesn't start... then you know where to start...
2001 996TT 3.6L and stock ECU
I am just a bit bewildered TBH. You haven't tried starting it again even though the car just died. Why didn't you just try turning the key again
As to the dash light well of course there going to come on the engine will have stopped so all the dash lights will come on as the ignition is still switched on
You might have absolutely no problems at all, it could just have been a glitch, there is no way anyone on here could diagnose a problem before we know it wont actually start.
If the car doesn't start then you need to get some codes with a Durametric. I got mine from here: http://www.hickleys.com/diagnostics/durametric.php
My 2003 tip 996tt died once without warning as I made a turn into the drive. Restarted again first turn of the Key.
I tried to start it at the side of the road - It would happily turn-over, but it wouldn't fire
I was only a couple of miles away from my house when it gave up on me, so I took the easy option and asked my brother to collect us
A little while ago my brothers van spluttered to a hault
He managed to get it started again, and then 50 miles down the engine let go and ate the block
I chickened out and opted to a tow as I can't afford an engine rebuild
Now that people have replied and told me it doesn't sound catastrophic I've just been out to try and start it again
Again, it's turning over, but not firing
