Strange fault codes
Strange fault codes
After installing a 200 cell Milltek exhaust I was initially getting the common fault codes P0420 (Catalyst Efficience Below Threshold Bank1) and P0430 (Catalyst Efficience Below Threshold Bank2).
After installing O2 sensor bungs/sensors I am now getting codes P0132 and P0152 and the two previous codes are not coming back.
BTW I have not reset the ECU after installing the O2 sensor bungs/sensors and I'm leaning towards thinking that this would possibly set things straight. Thoughts?
What on earth are these two new codes and is there a remedy?
JE
JE
Did you swap the O2 sensors? I could see you getting this code if you swapped the pre/post cat wires.
The 5 wire sensor goes before the cat and the four wire after the cat. One is gray and one is black. Ill check which is which when I can.
There could also be an exhaust leak. What level did you torque the cat to turbo bolts to?
